This area is not my greatest strength.
All that I'm familiar with is thyroid function testing to some extent...
but I can't read a liver function test to save myself.
Can someone here explain it?
I've seen some good results from acupuncture or herbs or bowen therapy, but I don't know much about lymph drainage/cleansing.
I'm also familiar with how much cardio is required to kick the BMR (basal metabolic rate) into play, but I don't how weights can extend the BMR timeline. I'd find that part interesting.
Discuss?
  • Like 2
https://www.sau.com.au/forums/topic/364943-metabolism-thread/
all I know is the more muscle you put on the more energy it needs to function which effectively causes your metabolism to be increased... cardio only really increases your metabolism whilst your doing it and for a short time after... but muscle mass uses energy even when your at rest
that's why resistance training is so important when your looking to lose weight (and by weight I mean fat)... aerobic exercise and low calorie diets will help you shed weight but a lot of that weight will be muscle... and on low calorie diets your body goes into starvation mode and metabolism decreases... so as soon as you go off the diet your body puts fat back on where the muscle used to be at a greater rate due to the slowing of your metabolism
I'm no expert but that's my basic understanding of resistance training and aerobic (cardio) and their relationship to metabolism
If you're trying to lose weight and you're doing everything right...
like...
* eating correctly with regard to 5 food groups + being regular + not picking/bingeing
* being active regularly
but...
your weight is stuck on these inordinately long plateaus
and...
* your skin is dry
* hair loses lustre easily
* have an intolerance to extremes of temperature
* suffer generalised fatigue
(say 3 of the 4 above)...
your thyroxine levels are probably running low
so...
your metabolism is sluggish
which means...
you can take the amino acid called "l-Tyrosine" to support your thyroxine levels
but how much?...
Ummm... I don't know unless...
but a thyroid function test would help!
^ ^ ^ Yes they can find it helps a great deal, especially over a timeline of 2 months or more when skin is more moist, hair tone and energy is better + weight comes off more easily if one was overweight due to this.
Hey Tez, T3 and T4 (triiodothyronine and tetraiodothyronine) are formed in the thyroid gland from L-Tyrosine and iodine so those supplements are the best way to start.
If you have a disorder with your thyroid gland which has trouble synthesising the hormone, you may get a goiter or enlarged thyroid as the brain will release a thyroid proliferating hormone to increase the size of the thyroid (similar to kidney hypertrophy or cardiac hypertrophy in compensation to say kidney donation or steroid use/valve regurgitation/stenosis)
A blood test can check for the hormone levels and go from there
liver function tests will look for free liver enzymes in the blood, let free from dying hepatocytes; an easy check for that is liver palpation under the right bottom ribs, systemic pruritis (itch) or a faint yellow tinge in the skin, eyes or fingernails from excess bilirubin
  • 1 month later...
You're correct nickr33 And in regards to the cardio/resistance training - resistance training helps increase lean muscle mass which in turn increases the metabolism (muscle uses more energy) and also keeps it going after exercise longer as muscles take longer to recover from a session therefore the body keeps working for longer. Cardio is a great way to the the metabolism firing but the body also recovers quicker therefore the metabolism isn't firing for as long. For weight loss it is important to have a combination of both cardio and resistance training in your program as well as the 5 veg, 2 fruit, carbs and protein daily (carbs and protein are important fuels for aerobic training) and remember not to overeat as well as aim for 1l water per 25kg of body weight plus 1l per 1hr of exercise :-) not drinking enough actually increases fluid retention which is a pain in the ass especially when trying to loose weight.
Arguable, some say things like green tea, chilli and those metabolift pills peak the mrtabolism but there isn't enough evidence to definatively say yes and even then it isn't a permanent effect, more like a placebo, people think it works so they train harder. Best is eat well, build lean muscle and increased metabolism will come with it. Plus you don't want to be relying on supliments forever. I'll do some more research and give you more details :) ill also ask the opinions of some of my lecturers and other trainers.
Yer its true dont want to be stuck on suppliments. Yer i would be intresting if there was a pill or something to boost your meta system to aid weight loss with diet and exercise. When you get to the aim of your goal, wouldnt you meta be at a stable place to give ujp the suppliment providing you continue the exercise and diet. hmm hehe
Cheers
Best way to do it is not waste the money on "diet pills" they aren't going to make spot reduction possible, they all say you still need diet and exerise programs if there was a fast simple solution to weight loss (other than don't put it on) than we wouldn't have the issues we do with obesity the thing is you are increasing your metabolism whilst doing the exercise and then trying to "boost" it with the pills which if they actually worked your body would still be used to the increased levels and when you stop them it drops back to a level it isn't used to because of the "boosting".
I was involved with a study at the ais on diet pills and the placebo effect, were all given exercise programs, nutritional coaching and a pt and either a placebo supplement or an actual diet pill and none of the pills proved to make any measurable difference in weight loss.
If you are after weight loss do mixed programs, eat well (including not over eating), drink plenty of water and make sure you recover properly between session (called super compensation process) so that you can keep improving your performance and pushing your body, warm up and cool down properly (including stretching) to aid with recovery and decrease the chance of DOMS (delayed onset muscle soreness) and in turn you will feel happier, healthier, your metabolism will increase and you will loose the weight, change your program every 6-8 weeks so your body keeps being challenged.
I could go onto the science behind exercise but that gets boring for most people lol
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
