  • Replies 65
dham it... this tread has it all posts where GT-R is mentioned in the same topic as the Soarer... now that just insulting period.
:domokun:
also i dont think R34 GTT is the same price range as Evo 8, but there are some nice Evo 7 going cheap.. i am guessing you will be looking at these not to mention the few Evo 7 GTA the auto version and Evo7 GTA Wagon.. surely there must be few on car sales
I also looked at GT-A's on Carsales yesterday, and from what I've read, seems to be a pretty decent package for a sleeper daily, no bonnet vents, no wing (optional), Triptronic, but everything else is an Evo 7. Pretty street/utility friendly being a sedan, too.
For about the same price of a 1995 GT-R you can get a 2003-3 GT-A.. Brand loyalty aside, the questions and comparisons do warrant looking into..
please no GTA and definitely no auto / tiptronic - I saw these GTAs the other day when lookin at EVO 7 on carsales and I went 'what the...' An auto evo omg..
And about soarers...erm nice boats them soarers...they remind me of a huge blob of jelly everytime i see one.....but they do have the best interior of all Jap sports cars....but again they are big BOATS to cruising to bahamas in.. :)
V35 is not much of a boat, it actually looks a fair bit smaller than a 34 taxi, and R35s could be erm - race boats or whatever you like to call them, but then again, a soarer is a nice - erm luxury boat, what do you guys reckon..?
I have driven an EVO 6.5 TME.
Was a fun car to drive and would make a nice daily.
It was stock with an aftermarket air intake and I could tell it had plenty of potential to open up the power.
Even though it only being a 2lt Inline 4, Turbo it was probably one of the fastest 4 doors I have ever driven.
Only thing I dislike about the EVO or Lancers in general, is the gearbox.
The engine is East / West position, hence the gearbox follows that position (FWD positioning) meaning there are linkages.
So while changing gears, it felt a little 'notchy' VS the Nissan gearbox, which I am use to, is very straight.
So the EVO has a different characteristic VS a Skyline.
Still an EVO would be a decent change from your GTT.
Luxury Yacht thank you very much hahah
Everyone should know its not about what can beat what. There will always be a car out there that will beat yours. Skyline, Evo, Rex, Soarer (Sadly lol), Charade (LOL), VN Commodore (LMAO). It's all about how much money you throw down the rabbit hole. It's what you personally prefer is the reason you get the car. It's your personal preference of what style you love to drive. This discussion will just go in loops trying to comapre each of them as they are very different cars.
Evos are great cars basically the only "Great" car that comes from the Mitshu's but they are not what I want and love to drive.
You will rape some and you will get raped by some.
Stock EVO 7 has 383NM, stock R34GT-R has 373NM and R34GT-T has 343NM, and I think the torque in the EVO comes on earlier too...
WTF is wrong with our bigger capacity 6 cylinder motors, even the over-hyped GT-Rs donk is less than this small 2L 4 cyl Mitsi motor..what an embarassment to the Nissan straight 6 clan, sure power isnt everything, BUT at least in this category we should have significantly more torque than the 4G63.
Theres nothing wrong with them. Chuck and exhaust, filter and the 14psi they deserve and away you go.
Ive never owned an Evo but I will at some stage, might even make it my next car.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
