Small bumps in the road on corners send my car skitting across the road with a huge shudder through the ass of the car. Possible causes?.... New 18" wheels fitted recently, rear shocks leaking something (not sure what) therefore maybe they are in need of replacement? Am I on the right track with any of this. Its a little disconcerting. I have king springs all round and have had no problems with them since I put them in six months ago. Any suggestions appreciated.
cheers
https://www.sau.com.au/forums/topic/36537-why-is-my-rear-skipping/
Dude, i had this exact same problem with my car awhile back.. turns out the rear shock absorbers were stuffed.. it stopped working completely. i say more that likele your rear suspension.. go to pedders and get them to do test your shocks.. it only cost $14 or something so worht it i reckon.
go to a decent suspension place(not sure about pedders) and ask them to check it out. most times I have done it at the one near me. they don't charge me to tell me what it is. then if the price is right I get it fixed there.
but yeah it sounds like the shocks are gone, oh well. guess its time for coilovers! :(
cheers
My car is doing the exact same thing. Will get my suspension looked at.
Thanks for this thread to all involved.
Yes that's what happened to me, the back would get all jittery around corners and over small bumps. I took out the back suspension and after I undid the pillow mount bolt on one of the shocks to get the spring off the shocky collapsed, I could push it all the way down and it would just stay there and when you lifted it all the way up and jiggled it it would fall down all by it's self.
I had previously taken the car to Pedders and they said that they where soft but other then that they where fine.
I have the same problem when going over small bumps (a good example is going "across" a main intersection where trucks have left big dips in the road). The rear end just sorta skips and I get a light squeel of the rear tyres (only under accelleration).
My rear shocks are only 10mths old, rear tyres are 9mths old and I've got Pineapples fitted.
Do any of you guys get axle tramp under accelleration ?
Yeah I think its the back right shock. Cause when I get under the car and shake the car there is a hell of alot of bumping/knocking going on coming from the shock. Oh well, hope this doesn't phcuk up my skidpan day on sat :devfu:
Anybody wanna sell me a set of rear coilovers?
I have the exact problem you describe, it appeared after a skidpan day. Wheel alignment and wheel balancing cured most of the problem but I still occasionaly get the shuddering.
I got my shocks tested at ABS and they said they are borderline acceptable, I say they are f*cked - every little bump gets picked up and the rear feels floaty. So time for bilsteins I think, or i'm considering getting standard shocks again ($170 each)
Greg just chuck in the bit extra and get Bilseins they are $245 each.
True, but its not the money thats deterring me from the Bilsteins, its bumpy roads! I think the Bilsteins will be a bit too stiff. But I guess there's only one way to find out. Hmm and then there's the decision of Whiteline vs Bilstein, although apparently they are similar :
craz0 thanks heaps for your help! :D i posted a thread on this topic but no one replied! I'll go ahead with the bilsteins, keeping the standard springs because I need the ride height to clear driveways and bumps etc. thanks again
edit: just looked at your photos and was amazed to see your car is the same colour as mine (paint code KN6, yeah?). yours is the only other skyline i have seen in our purplish/dark grey/charcoal colour! I was beginning to think my colour was a custom order or something :) anyway laters,
sorry for the hijack of thread i recommend you get a wheel alignment and wheel balance for starters, could save you a lot of money.
Slamm, definately sounds like your shocks are rooted. Also coil overs are completely overrated when it comes to road grip, that is unless they are setup correctly and used with the ideal ride height. Sounds like you have good springs already so some good shock inserts for your standard struts would be a cheaper and more suited to your criteria, that is if you want to grip not slip!
Greg, for the roads you travel on, I would recommend a firm spring with a medium gas insert. From experience too firm on the shockers results in too much steering effort.
I am glad that my nismo shocks and springs are still good at 100,000k and when they do give up I hope to get them kitted and reuse them.
Thanks to Prank for fixing the new posts tab, that is probably why Greg's thread went unanswered. :)
thanks for all the input ppl. My shocks are screwed. at least one is. Oil (or fluid whatever) is leaking everywhere. They are standard 33 struts replaced when I got my springs done. I lowered the car a month after buying it and when we pulled the old struts out they were both bent. possibly caused by the car being strapped down tight on the boat over?!! the dealer i bought the car from replaced the old struts with, well, another pair of old struts and six months down the track this is where I am. the handling is shocking atm. just like a boat. will tell you how I fare tomorrow at skidpan day. I know I probably should be wary of going tomorrow but I will make a decision there as to how it feels.
still nobody got some old dusty coilovers or adjustables they want to get rid of? or maybe I should learn a lesson on 2nd hand stuff. you just never know.....
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
