  • Replies 3.6k
Posted Images
If someone laughs at you for not making massive KW's then they have a problem. I say do it for shits and giggles and at the same time you can find out what your car is actually making :D
Who cares about power. I would laugh at him for owning an AU
OK..i have a big ugly caryard sticker on my rear windscreen its the chippy reflective vinal stuff :sick: .
I would like to remove it , im asking suggestions before i attempt this as i know it will get messy.
I was thinking of using Bug & Tar remover (worked wonders on the debadge.)
Please help.
Hair dryer / Heat gun awesome idea.
I did sort of try it but due to the type of vinal it chips off in vrey very small portions.
LOL.. This sucks may take a while :rolleyes:
Thanks for the help.
Stanley knife blade.
I know there's 8000 hicas threads but i think it's worthwhile to post a question on here rather than scour the abundance of info straight away. My hicas light on my dash has quickly flashed once on two separate driving occasions. I have no irregular steering symptoms but I have noticed both times it happened just after taking off (normal driving) and slight steering movements. The car was serviced on monday I figure it might be a bit of air in the system or something. Anyone got any ideas?
Hicas is not locked or bypassed all standard in that department. Will be happening soon though..
fluid sensor on ur powersteering. possibly needs a top up to cope with +ve g's
On another topic
Anyone wanna go to Burger Foundry?
Want to stab a dolphin in the face unless I get one of their tasty burgers....
save the dolphins. drive dohmar to burger foundry.
-D
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
