  • Replies 3.6k
Posted Images
well bad news for me, the stagea is dead.
refuses to drive any further, being towed to boostworx on monday (was trying to hold out till start sept when the house sale goes thru, but cant any longer)
that sucks!
My car has been towwed to boostworx about 4 times in the past 2 months.
its been behaving itself recently, ever since the fuel pump's have been fully rewired.
just ordered a Nismo engine mount kit for the GTR. and super pro gear box crossmember bush kit.
hopefully it'll solve the clunky noises through the trans over bumps.
Well Scandy and I just went out after lunch at the BBC and bought Duke Nukem: Forever .... and after install it wants to do a massive Steam update - it has already been updating for 10 minutes at 500kb/s and is not even 10% updated .... FFS I WANT TO PLAY IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It's nothing mind blowing but if you played Duke3D it's more of the same toilet humor that made it famous. I quite enjoy it for a mindless shooting romp
Yeah the toilet humour is definitely a big drawcard :) ..... and "time to kick ass and chew bubble-gum" :D
You're face or you're ass.... what's the difference?
P.S. Check go kart night thread in exec section
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
