  • Replies 3.6k
Posted Images
So the latest with my car is that I dont think its the turbos. After finding some long fingers and taking more pipe work off they spin fine with no play. The swirl marks that I saw from down the mirror where just fine oil and dust.
Going back to the cat it wasn't collapsed but it has a bit of carbon build up in it. Would this cause a huge restriction. It also has a blue tinge to it so it suggests its getting hot. After the shudder the exhaust note was quieter.
If I had blown a turbo I would of thought I wouldn't get any boost?
Im still getting 10 out of the 20 that it was set to. Plenty of pressure on the wastegate.
Ive checked all pipework and boost hoses. Car still starts and drives ok it just wont get the boost it used too.
Have I missed something before I put it all back together? Or do I need to pull more apart. I havent checked the back of turbos they are N1s so I would think the wheel is still there.
If I were you Brad I would take the GTR for a quick burn (very late at night) with the exhaust and cats removed and see if it will make 20psi. If it does, then it rules out the cats or collapsed exhaust out of the equation.
Bit of work done today. :)
Motor in, then gearbox in, now tomorrow to cut intercooler holes :)
nice!
ps: on your yahoo travels luke, can you keep an eye out for a 4" hks super drager cat back for a jza80 for me ? do u know how much they go for...need 1 real soon...? Thanks.
Good to see that thing getting together now. Will come and lend a hand/have a beer with ya when I am free mate :D
I just worked out the cause to my boost problem. It was a half blocked cat. There was a fair bit of carbon build up. It was very black inside. The cat should be a nice brown colour inside from the carbon being burnt off. Anway did the cowboy thing and bashed it out. Now the car boosts even better than before.
Since were talking about tunes. Should I get my car tuned again? Only because last time it would of had a part blocked cat. And now it flows better.
I always thought running N1s @ 20psi would get more than 265awkw.
not sure if anyone has read this about iphones/devices, but really apple didn't test them in australia based upon the temp restrictions did they ? even outside the car they get over that hot ?
Apple over temp warning
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
