  • Replies 3.6k
Posted Images
So the latest with my car is that I dont think its the turbos. After finding some long fingers and taking more pipe work off they spin fine with no play. The swirl marks that I saw from down the mirror where just fine oil and dust.
Going back to the cat it wasn't collapsed but it has a bit of carbon build up in it. Would this cause a huge restriction. It also has a blue tinge to it so it suggests its getting hot. After the shudder the exhaust note was quieter.
If I had blown a turbo I would of thought I wouldn't get any boost?
Im still getting 10 out of the 20 that it was set to. Plenty of pressure on the wastegate.
Ive checked all pipework and boost hoses. Car still starts and drives ok it just wont get the boost it used too.
Have I missed something before I put it all back together? Or do I need to pull more apart. I havent checked the back of turbos they are N1s so I would think the wheel is still there.
If I were you Brad I would take the GTR for a quick burn (very late at night) with the exhaust and cats removed and see if it will make 20psi. If it does, then it rules out the cats or collapsed exhaust out of the equation.
Bit of work done today. :)
Motor in, then gearbox in, now tomorrow to cut intercooler holes :)
nice!
ps: on your yahoo travels luke, can you keep an eye out for a 4" hks super drager cat back for a jza80 for me ? do u know how much they go for...need 1 real soon...? Thanks.
Good to see that thing getting together now. Will come and lend a hand/have a beer with ya when I am free mate :D
I just worked out the cause to my boost problem. It was a half blocked cat. There was a fair bit of carbon build up. It was very black inside. The cat should be a nice brown colour inside from the carbon being burnt off. Anway did the cowboy thing and bashed it out. Now the car boosts even better than before.
Since were talking about tunes. Should I get my car tuned again? Only because last time it would of had a part blocked cat. And now it flows better.
I always thought running N1s @ 20psi would get more than 265awkw.
not sure if anyone has read this about iphones/devices, but really apple didn't test them in australia based upon the temp restrictions did they ? even outside the car they get over that hot ?
Apple over temp warning
    • Hi, i’m making a rb25det coil loom for Vag short coil. Can anybody tell me which Ecu signal wire belong to coil number 1 and 2,3,4,5,6? The connecting switch in above pic is 8 wire i think white is for +12v and black for earth.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
