  • Replies 3.6k
Posted Images
So the latest with my car is that I dont think its the turbos. After finding some long fingers and taking more pipe work off they spin fine with no play. The swirl marks that I saw from down the mirror where just fine oil and dust.
Going back to the cat it wasn't collapsed but it has a bit of carbon build up in it. Would this cause a huge restriction. It also has a blue tinge to it so it suggests its getting hot. After the shudder the exhaust note was quieter.
If I had blown a turbo I would of thought I wouldn't get any boost?
Im still getting 10 out of the 20 that it was set to. Plenty of pressure on the wastegate.
Ive checked all pipework and boost hoses. Car still starts and drives ok it just wont get the boost it used too.
Have I missed something before I put it all back together? Or do I need to pull more apart. I havent checked the back of turbos they are N1s so I would think the wheel is still there.
If I were you Brad I would take the GTR for a quick burn (very late at night) with the exhaust and cats removed and see if it will make 20psi. If it does, then it rules out the cats or collapsed exhaust out of the equation.
Bit of work done today. :)
Motor in, then gearbox in, now tomorrow to cut intercooler holes :)
nice!
ps: on your yahoo travels luke, can you keep an eye out for a 4" hks super drager cat back for a jza80 for me ? do u know how much they go for...need 1 real soon...? Thanks.
Good to see that thing getting together now. Will come and lend a hand/have a beer with ya when I am free mate :D
I just worked out the cause to my boost problem. It was a half blocked cat. There was a fair bit of carbon build up. It was very black inside. The cat should be a nice brown colour inside from the carbon being burnt off. Anway did the cowboy thing and bashed it out. Now the car boosts even better than before.
Since were talking about tunes. Should I get my car tuned again? Only because last time it would of had a part blocked cat. And now it flows better.
I always thought running N1s @ 20psi would get more than 265awkw.
not sure if anyone has read this about iphones/devices, but really apple didn't test them in australia based upon the temp restrictions did they ? even outside the car they get over that hot ?
Apple over temp warning
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
