  • Replies 3.6k
Posted Images
How much and where from matty? Ive been looking at the whole kit lately, hopefully it might resolve the choo-choo turbo shuffle the -5s have
Kudos Motorsport pete. The suction kit was a tad over 1300 freighted from qld. Hard pipe kit installed last week was 650.
Somehow I dont think its the boost flutter you have to worry about pete (stock wastegates ftw) :whistling: You still attending the dyno day? I can't wait to hear your 33 at full noise in the shed :D
Yeah I'll be there don't you worry.
Does that suction kit fit your stock afms or only z32s?
Aaah should've mentioned that... I got the last kit from kudos that is compatible with stock afms. The rest are Z32 jobbies.. I'm gonna cheat and use nismo items..
It might pay to have a bit of a google and find out which brand you prefer the look of mate, some people prefer the HKS kit, good luck finding one in oz though!
Only problem is now my inlet plenum would look much better chromed and polished, looks like my stealth engine bay approach is dead :whistling:
Anybody know the best place to buy a Nistune for series 2 rb25 r33? An do you need to supply your own ecu or does it come complete to bolt in?
I didn't think these were supported, so I checked their website (http://nistune.com/equipment-products-type2.php):
• ECR33 Skyline (RB25DET)*1
*1 ECR33 RB25DET Skyline can use HCR32DET ECU (no VCT) or Z32 VG30DETT ECU (internal modifications required)
So yeah - R32 ECU if you don't want VCT, or Z32 ECU if you do.
Yeah nismo afms is what I'm running too hence why I mention it. I think I'll probably just import one when the time comes. It's good to know it works with the stock size ones though, I couldn't find any info about it on trusts website.
Sorry pistol I may not have explained that properly. The greddy kit comes in two variations: standard afm and z32 afm compatible. I managed to snag the last one on kudos' shelves that retain stock items.
That way I can run nismo afm's later on if need be. try www.rhdjapan.com .... never fails :)
So you bought two separate kits, the intake and the I/C piping? Thought they came in one kit?
Yep seperate kits. The "Hard Pipe Kit" replaces the factory rubber i/c piping. The "Suction Kit" replaces the factory intake piping and airbox. A smidge under 2k sent to my door..
yeah thats what i wasnt sure of as i hadnt been able to find anywhere selling the standard size version, even rhdjapan
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
