Bosch EV14 1000cc ID1000 style
These are a 3/4 length injector, 14mm Oring, top feed, high impedance, UScar style plug.
Tuff Car Parts can sort you out for those Adrian
steve i want anything 1000cc that will fit under my plazmaman!! LOL
status said those side feed are highflows
  • Replies 3.6k
Posted Images
i want to convert to top feed as they are cheaper/bigger cc/easier to find.
if i can find some genuine 1000cc drop in side feeds ill get them.
its either top feeds dont fit or side feeds are hiflows or not avail!
FML
Wow the Aussie dollar is in freefall after the USA debt bailout announcement - $1.10.7 2 days ago, has just bottomed out at $1.07.0 - better buy up any parts you want from overseas now kids!
Eyebrow height is the one point, but there are others, like "the distance between any part of the
vehicle and the ground is not less than 100mm."
It should all be documented in the following:
http://www.transport.sa.gov.au/pdfs/personal_transport/light_vehicles_pdfs/MR1136_Requirements_for_Lowering_or_Raising_Vehicle_Ride_Height.PDF
http://www.transport.sa.gov.au/pdfs/personal_transport/light_vehicles_pdfs/fact_sheet_track_suspen.pdf
Anyway, familiarise with the above, and call Regency Park - you may even get a straight answer.
If they abolished eyebrow height you could technically be on the tyres with 100mm clearance still, and one would think that you need some sort of clearance between guard and hub to allow for adequate suspension travel, so logically, there should still be a eyebrow height law, in my head anyway...
My V35 is the opposite - I have bucketloads more eyebrow clearance than legal/desired and my exhaust (which has been modified already to be as close to the car as possible) is still way under 100mm clearance and bottoms out on EVERYTHING :(
Pretty sure that is all that is sold in Aust'. Infact i think they are all HSPA+.
when i was looking they were about to release the 4g. that was 2 weeks ago. so wuld have been out by now..
i would have got it but im with optus!
and steve i watched that yesterday when i signed up to xda... LOL
Currently doing the 4g roll out on all existing towers at my new work, you probably won't see proper 4g Australia wide for another 12 months. They might release 4g phones now but they will probably just run at 3/3.5g
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
