yea think my fronts are 17x8 too. Ah so it'll be no issues if I get a smaller size then?
I'll call them up tomorrow I spose, but just for now, how much do you reckon I'd be paying for each? If you know that is
thanks again!
  • Replies 3.6k
Posted Images
ive got a pair of Nitto NT555 i think they are ready for the drags 275/?/17 with rims if anyone is keen. fit under the guards of 32-34 and S14. can supply pics or come have a look and suggest a price. need to get rid of them
Have asked a few thing's on here and never get an answer but I'm getting desperate.
Has anyone on here ever asked their work for a transfer within a company that own's the company you work for?
Like, you work for Business A but Business B offered you a job but both businesses are owned by one big company. (hope that makes sense)
Having trouble as my work doesn't want me to go so giving me the run around trying to get a transfer out! Need help
sorry one more question actually.
would you recommend getting more ku36's? Its purely a daily driver and I know they're not necessary but I kinda liked them lol. Any other tyre recommendations perhaps?
KU36's are cheap so if you like them I would suggest you should stick with them lol. I personally love the RE001's, but they are a touch on the expensive side.
That should not be a problem, especially if they are sister company's. If anything i would think the transition would be a lot smoother by doing that rather then trying to transition to a completely different company.
So anyone know of any cheap car parks in town in the area between sort of light and Victoria square that would accommodate a "lowered" car? Just started working on a site on franklin st and ill be here for a couple months.
I'm not far away from some bent chassis rails already haha
Mm its always a tough one, even though they are owned by the same company, they still run as two. Its not like going from reception to accounts, you are essentially leaving their workplace to go work elsewhere.
It's becoming a problem :(
My work now won't release me to the other company because they don't want to lose me but if I don't go, I miss out on a huge career oportunity and a lot more money!
Can't contact HR because they are the main problem :s
Going into the office to start swinging today or tomorrow and see what happens.
Ouch that is not good to hear. Normally with these sort of problems you just head to HR but if they are the ones creating these problems then goodluck lol
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
