  • Replies 3.6k
Posted Images
i only drove from Andrews to home and i haven't setup the electronics but seems better travel/rebound but they're newer technology
so ill clean up the old ones didn't see like there was any leaks which i wouldn't suspect as there was no knocking
R33 V10
OHH YEAH
just because you can doesnt mean you should !!!!
I had a V10 in my 4x4 dodge truck lets just say. dissapointed . the quality was shocking bad !! . Japanese tech/dependability any day
i prefer this v10 build http://forums.vwvortex.com/showthread.php?4515333
:laugh:
that i find hard to believe Nick
well, got my new toy today. I swear im nuttier than a fruitcake sometimes
(for reference, it does have a grille, was just holding on by one screw, so removed it for now LOL)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
