  • Replies 3.6k
Posted Images
Who's got any recommendations on guard rolling? My mate is running 9.5s on his s15 and wants a bit more clearance on the rear. I told him I could do it easily but the results would differ from a professional job haha. Where should I tell him to take it?
Depends on what he needs done..to have to lip rolled up all the way I have had about 5 cars done at wheelworx and have been happy everytime. Most wheel / tyre places won't get the lip the whole way up. Wheelworx made their own guard roller and Joe knows his stuff
My guards were rolled by Scandyflick using a mallet and heat gun, far cleaner than many 'professional' jobs I've seen. Results always differ, but I didnt have any paint cracking.
i was gonna say, wooden or rubber mallet+heat gun+patience
All you RB20 people out there.
Brothers 32 is running abit weird. It has splitfires, 040, stock turbo, new plugs etc
When driving it, it hits around 38-4000rpm and cuts power (basically back down to 1500rpm then climbs again, then cuts)
I've checked the ignitor and AFM (borrowed others) and that hasnt fixed it.
The car doesn't get driven much so any help is appreciated.
Next step would be gap some new plugs (current is 1.1 or 1.2)
cant give Kudos Motorsport a more high rep
purchased parts a year ago and he couldn't supply the parts Andrew offered a full refund minus the parts he supplied and i said i would be happy to purchase more parts later which brings me to now
after deciding i didn't want to purchase more parts Andrew was willing to refund the price of the pars
very happy would happily use again
Try ignition pack, mate had a problem with his recently were it would drop revs and cylinders until he got a new one. If not I'm on the ECU train
Tried the ignitor and didn't fix it. Will try ecu, if that doesn't fix it been told maybe tps sensor.
tps wouldnt kill the throttle, tps is only there for response. if the tps is unplugged you can still run the engine
do you have a consult cable? I'd be chucking that on and seeing if there are any ecu error codes...
does the car idle OK?
-D
+1 steve. Ive only dealt with them twice but both times Ive been very happy in all respects
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
