I'm trying to fix my harness in properly and having some troubles. Anyone know where I can get or have made a 10 x 1.25 pitch eye bolt? Very much like the link following
http://online.covent...section=3215688
try probolt australia
or coventry fasteners in town
  • Replies 3.6k
Posted Images
who do u have to get ya misses to blow to have a shot :rolleyes:
just found out today the simulator will be at the Life FM open day you can have a free shot and say hello to Mark let him know your on skylines australia and Steve said to meet him
http://www.life.on.net/index.php/len-and-pete/48-general/150-life-fms-big-bbq-day
no probs Andz.
had full 100k service with gates belts, som exhaust mods including screamer, new coilpacks cos the JJR's shat themselves, adjustable cam gears with clear cam gear cover, carbon air box, carbon valley cover, silicone intake pipe with apexi power intake, plus all the gear still on it when i sold it.
No links yet, facebook based only at this stage.
on another note, who knows if R34 GTR fenders fit a GTT
They will, but won't line up with a GTT front-bar. I also suspect the inner-guard liners won't fit right either (not sure if GTR guardliners would fit, but I'd assume so).
Of course, if you fit a GTR front-bar, it won't work with the GTT bonnet - and then you need to change the bonnet, latch assembly (bit that holds the horns, bonnet latch, etc), the bonnet latch itself, and the hinges over to GTR items.
yeah anything GTR onto the front of a GTT basically means front end conversion. unless you buy fibreglass gtr guards that are made to fit GTT, same with front bar
I have a new body kit, bonnet and front bar for GTT only , but looking into a carbon Z tune front fenders marked for GTR
Edited by Carbon 34
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
