Joolya has 19% support within her own party whilst Kevin07 has 42% & rising by the week. Her own people no longer believe she has the goods to lead them into the next election. LOL @ the ALP = Joke Factory....Crazy Mary Jo Fisher would get my vote for PM :-)
  • Replies 3.6k
Posted Images
Joolya has lost the plot! She's decided to ignore the "High" court's decision & legislate her own law to enable offshore processing. She's gone from unpopular to outright dangerous. First she doesn't listen to the people re Carbon Tax & now ignores the highest court in the land!!
wow, i have not heard of this, but this is insanity. Something needs to be done TODAY!!!!!
well it looks like my house sale contract is falling through; signed back end May and had extensions of time-frame until end this month to enable the buyer to sell their property (x2). Buyer refused a recent reasonable offer, now the agent wants his selling fees paid out - money I dont have & wouldnt have had until a sale had been formalised. Bit of a bullsh*t situation but thats the current RE market.
Been going through a horribal withdrawal period from the drug fentanyl as Ive been tapering down the strength. About to get off it completely as from mid this week; going to be a rough few weeks ahead. Past 2.5 weeks have been nothing short of awful. 80x the strength of heroin. If you have ANY loved ones who are about to be prescribed Fentanyl (Durogesic patches) PLEASE PLEASE pleade with them NOT TO get on it. It works against your central nervous system and withdrawal is horrible. Attached is a little info if anyone is interested. Ive only recently realised how much it has messed me up, my research recently has explained to me why I feel that way I do. Every 3rd day Ive been into withdrawal for over 3yrs now. Ive got to be strong now and work my way out of the hole Im in.
The Duragesic.docx
you can move to Detroit cheaper , I saw a house go for 130 dollars yes thats a correct price ..lol . orginal cost was 250k . before the crims stripped the copper pipes and wiring out of the house and the banks had 1000 of repo's the show I watch had hundred of house left abandoned on one street in detroit alone.
tell the agent get farked, sell your house like he is supposed too . they hover over like buzzards for money. and if hes wearing a gold jacket kick him in the sack for me.too..haha
Bit of a basic question.. But how can I tell if my HICAS rack ends, or ball joints are worn?
Can I just grab the rod and shake it about and look for movement? Or does the rod need to be taken off and each joint inspected using a proper method..
Jack the rear of the car up so both rear tyres are off the ground, then wiggle the wheel by hand and see if it moves.
I've tried that, there's maybe 1mm of play in the rear left, it's difficult to see where exactly the movement is coming from.
When driving the ass of the car is all over the place and feels like a lot more than just 1mm of play.
hey nick have you got a lock bar?
rear cradle bushings or one of the control arms ? bad shocks ? broken or loose sway bar. rims loose , bolts on the rack loose ? have a real good poke around bet you see something ,
axle slipping out of the rear diff ?
Edited by sapphiregraphics
Jetturbo, u know anyone selling some ford Gt brembo 4pot rear calipers? I need some for the 34
hens teeth on that one luke they only came out on the top of the line GTP or if u optioned them wich very few ever did due to the huge cost ill keep an eye out for u tho bloke :thumbsup:
I've just got rid of HICAS because the rear was out of control.... Was just doing whatever it felt like
Did you just chuck on a lock bar?
Driftworks have a nice kit that replaces the ball joints etc and all, bit costy though :/
Guest
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
