The more stages the more oil you can circulate and the more vacuum you will pull in the crank case.
On a race car I normally use either a 4 or 5 stage. On a milder street car/weekend car I'd go a 3-4 stage tops.
Alot of people use a 4 stage and scavenge 2 from the sump and one from the head. It's not wrong but it's not ideal. The idea is create vacuum In the crank case and putting a scavenger in the head is not exactly helping to draw the oil to the sump pan where the remaining majority scavengers are trying to work.
Vacuum is always equal in all directions if the container ( engine) is sealed so scavenging from the head won't effect the vacuum levels but it is best if you can get all the oil flowing in one direction with gravity to the bottom.
With a 4 stage I'd normally run three pick ups in a sump channel. One from one center and one rear. With a five stage like my old race car had I'd use two channels one in front of the subframe one behind both with two scavengers feeding from them.
There is hundreds of sump design ideas out there nothing is really right or wrong, people scavenge in all different ways from all different positions.
I'd be interested to hear from others as to what they do with their scavengers and positioning.
On my road car I have a 3 stage to use. Two scavengers one at the rear ( scavenger on acceleration) and one 1/3 the way down the pan towards the front ( enough for heavy braking but far enough back to scavenge on acceleration too) usually with a 3 stage you will end up with excess oil in the pan, depending on the sump and channel design.
I'm doing a pan for an s15 at the moment for a 4 stage Peterson pump. The pump will be build into the pan and have internal scavengers when it takes some shape I'll put up some photos.
Our Motive DVD S14 time attack car needs a dry sump due to oil surge at high g-force.
interested to see what you come up with
This thread seems really appropriate considering I had my first go at hacking up a standard sump to design my own dry sump pan. I have a bit of an idea on what I want to achieve but still not 100% decided on the final design. I am thinking something like the below... all the designs seem very similar. I will be putting the baffle plates back in and also make a fancy crank scraper to help.
I am thinking two pick ups in the rear and two in the front. The way it is divided because of the front shaft is really annoying.
Mike cut the lip right off and make the sump floor flat.
Don't angle it upwards towards the lip,
I can send you down a "kit" ready to shape and weld together of you like.
Just need to cut the sump to suit and thrown it in a mill to get a spot on flat surface to begin with.
Email sent Brad :)
Sorry for the noob questions.
What are the options for an RB25 or RB30 block as far as sumps ?
Other than the Hi-Octane one, are there any alternates ?
http://www.hioctanedirect.com/index.php?main_page=product_info&cPath=67_74&products_id=1828
Or would it be cheaper to use an RB26 dry sump and block off the diff holes ?
Is there any reason that you have to make the sump flat bottomed and reduce the holding capacity, or is it possible to use a normal 5litre sump, and then further increase the volume with an additional dry sump tank ?
Lol, the whole reason it's called a "dry sump" is because the sump pan on the engine is no longer used to store the engine oil. Hence it being dry.
There's just no need and in fact it's detrimental having all that oil sloshing around in there.
No point using a 26 sump on your 25 or 30. A fabricator can mod your current sump for use in a dry sump system easily.
Thanks :thumbsup:
If anyone has a spare rb25 pan laying around I'll grab it off then and make up a dry sump pan to put photos up of how I'd do one.
I've made plenty in the past but hadn't ever bothered taking photos of them.
There is plenty of different ways to do it but once people see photos of how it can be done itll become common knowledge.
Don't forget me Brad ;)
That would be awesome :thumbsup:
Look okay.
I'm not a fan of large channels like that I rekon they are too wide and allow the oil to ride up the wall a it gains momentum.
A narrow deeper channel prevents the oil from "picking up speed" and riding up the wall of the channel.
I've almost finished off a new barra 6cylinder pan which I'll post up photos of tomorrow before it goes to get made in carbon. It's a big setup with a 6 stage Dailey engineering pump.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
