i know there is quite a few threads out there about this and i've read through a lot of them
i probably see redline mentioned the most and for every post for redline there is someone to post against it for whatever reason, as well as motul
i've just bought a gt-t, i've already done the engine oil and will be looking to do the g/box and diff soon.
i don't mind spending money for decent quality gear
is there really a problem with redline (seen a lot of people mention it's not for gearboxes with syncros)? though i've not seen that for sale at autobarn/supercheap here in brissy
same goes for motul?
or should i be just looking at castrol gear?
thanks
https://www.sau.com.au/forums/topic/365686-gearboxdiff-oils/
shit wrong forum section
yeah that seems to be what a lot of people are saying
redline lightweight shock proof?
For what it's worth the gearbox is in really good condition the gears practically click into place, can be hardish to get into first and 2nd when cold though. No crunching
should i go redline mt90?
Edited by mystery_kid
I think the reason alot doubt on the redline is because it is made for racing not daily driving so there is no real need to put it in a street car..same goes for stuff like motul 300v chrono engine oil.its not designed for driving to the shops its designed to go round a track at 200+kmph so putting it in your daily is not only a waste of money it could potentially do more harm than good
so the question is what are you using the car for..
anyway there is a whole thread on driveline oils if you cant figure it out for yourself you havent read the thread properly and asking again here isn't going to give you a NEW answer because we have all read the same thread..
At the very start there is this
For a sticky.............................
What we use;
4WD Transfer = Castrol Transmax Z
Automatic Transmission = Castrol Transmax Z
Manual Transmission = Castrol Syntrans 75W-85 or Castrol Syntrax 75W-90
Differential = Castrol SAF-XA
this man races cars, I believe with some success so maybe he knows a little about oils..
However if you are thrashing the crap out of your car sideways well you may think you want a little extra protection so you could spend on the redline, just remember its designed for high powered racing if this isnt you its a waste of moeny.
So the question is, are you racing a high powered skyline or just driving a skyline?
yeah arthur, i completely forgot about this section of the forum when i posted this thread, i originally posted it in another section it was moved here by an admin
i've been through that thread and yeah i will go with castrol
it's a daily with maybe 3 or maximum 4 track days a year in it
dont get the vmx-80..
I did cause it was cheap but its junk, well its ok once it warms up, but it takes half an hour to warm up :)
Get a multigrade, Ill be getting the syntrans or even the penrite gear oil is ok too I think, it feels good in my diff anyway
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
