hello was driving home today when i heard a snap/bang etc
turns out the front driveshaft ripped out the wiring from the gearbox and to fix it is basically a gearbox out job (cant get to where its been ripped)
after a bit of web browsing i have come to understand that these wires are there to tell when the car is in reverse and neutral.
can anyone confirm this?
if so i can only think it would cause for there to be no reverse lights. would there be anything else?
thanks
yes that's right, it is neutral and reverse switches. reverse for reversing lights, and neutral is an input to the ECU for some reason.
You should not have to remove the gearbox. put a jack under the rear of the gearkbox and undo the 4 cross member bolts. slowly let the jack down until the attessa line at the rear starts to get tight. that should give you enough clearance to get at everything.
there is a short wire from each switch to a plug. the plugs go into the front body loom which includes starter motor and a few other things. should be easy enough to repair if the loom is damaged....depends where the wires broke.
thanks duncan. well i think ill leave it for now if its only going to effect my reverse lights. from what ive felt the wire's snapped off right on the plug. incase i do decided to get it fixed in assuming the plugs going into the gearbox screw or pop out? otherwise connecting wires back up to the plugs even with the gearbox hanging down may be a bit tricky.
  • 3 weeks later...
Does anyone know the wiring for a r32 box? The loom connectors have been ripped off mine so i dont know which is the neutral and reverse. and which is neg and pos on each?
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
