every one has diff ideas on safe boost for a rb25 det neo :thumbsup:
my car mods are
the HKS gt-rs turbo kit
steel head gasket
head re-grind
full top end stud kit
hks timeing belt
pro cool intercooler
hks pod filter
440 fuel pump
full engine flush
new belts all around
hurricane custom 3inch sports exhaust ( cat and cannon )
after market radiator
split fire coil packs
hks elec boost controller
if i remember the other mods ill post
but im lookn at running about 15 psi on high and maybe 12 low waiting too see what the lowest the actour can handle
any help would be nice about this subject ((( or should i just run like 13 daily)) :unsure:
anyone whith this kit let me know what ur running and mods
Edited by Addicted2BoostR34
https://www.sau.com.au/forums/topic/366032-rb25-det-neo-safe-boost-presure/
The safe boost level that you are probably referring to, is if you have standard turbo....
After that is replaced with after-market turbo(steel wheels) the problem is now safe power level for engine output (kw).
May as well tune & run 20psi(or whatever the highest boost efficiency range is) , then use your right foot to achieve desired boost.
Edited by Shazza24
Boost pressure has nothing to do with "safe limits" on an engine.
10psi from a T28 is a lot different to 10psi from a T88.
As has been said, the only reason people refer to safe limits of boost pressure is on the stock turbo.
Your HKS actuator on the GTRS is a 1bar item so the minimum it will run is 1bar. They run out of puff at around 19-22psi dependent on engine.
But +1 on what ECU are you running? Please don't say stock.
stock ecu pinch.gif as im still not sure wat one to get my tuner would like me to get the vipec ecu.. but i like the Fcons with hand controller :pirate:
maybe even a nistune ?:S
as for fuel pump i ment the 040 in tank fuel pump
the 440 is the inline version
injectors are stock as im going to do them at the same time as the ecu
my plan was to get the gt-rs turbo on run it at min bar ..
get the head cleaned up
upgrade the pump
timeing belt exc
get some forged items in her belly :) do supporting things water / oil pump then once thats all done lookn into tuneing and injectors 2 match
i drive this car f*k all its a long term thing for me
the 040 pump will be fine for the gtrs, the 044 is the external pump your thinking of...
the vipec ecu seems good from all accounts and so is the nistune but the Fcon is harder to find a tuner for Ive heard, if you want a hand controller go the powerFC, but at the end of the day get what your preferred tuner has the most experience with and recommends...
you say you have 'hurricane custom 3inch sports exhaust ( cat and cannon )' tell me you will have a 3 or 3.5" dump as well....
I wouldnt even worry about a pod filter just run the std airbox with a decent hiflow panel filter or an arc airbox... pods are ghey imo.
Im assuming you meant 'cooling pro intercooler'... yeah.? never heard of a pro cool one...
with injectors keep in mind that E85 is around more and more and to run it you need 30% more fuel flow, more power, less detonation more timing...
Yeah ECU first pretty much in all instances.
Without it, forget running more than 7-9psi as the ECU will simply have a fit, not to mention you need injectors.
Have you even read the "what mods to do first" thread?
The RB25 dyno sticky?
You'll soon notice if you read every GT-RS thread, what the minimum requirements are.
yer 3" turbo back
pod was on it wen i brought it was thinking a nice metal fab'd one
and it would be 'cooling pro intercooler' that was allready on it wen i got it too ...
vipec it is i need to sell my bike and it will be done !!!
(injectors will be done wen ecu gets done ) so i will prob drive it like twice after the turbo goes on
i hae tryed 2 look for posts about the vipec but the button wont let me look it wont even find skylines pinch.gif
If your tuner wants the Vipec then go for it. Fantastic ECU and you will not be dissapointed.
Don't worry about half the stuff you listed that you want to do. Get the injectors and ECU done first.
its all done once i sell bike ecu and injectors :)
YZF400 any1 keen :P
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
