every one has diff ideas on safe boost for a rb25 det neo :thumbsup:
my car mods are
the HKS gt-rs turbo kit
steel head gasket
head re-grind
full top end stud kit
hks timeing belt
pro cool intercooler
hks pod filter
440 fuel pump
full engine flush
new belts all around
hurricane custom 3inch sports exhaust ( cat and cannon )
after market radiator
split fire coil packs
hks elec boost controller
if i remember the other mods ill post
but im lookn at running about 15 psi on high and maybe 12 low waiting too see what the lowest the actour can handle
any help would be nice about this subject ((( or should i just run like 13 daily)) :unsure:
anyone whith this kit let me know what ur running and mods
Edited by Addicted2BoostR34
https://www.sau.com.au/forums/topic/366032-rb25-det-neo-safe-boost-presure/
The safe boost level that you are probably referring to, is if you have standard turbo....
After that is replaced with after-market turbo(steel wheels) the problem is now safe power level for engine output (kw).
May as well tune & run 20psi(or whatever the highest boost efficiency range is) , then use your right foot to achieve desired boost.
Edited by Shazza24
Boost pressure has nothing to do with "safe limits" on an engine.
10psi from a T28 is a lot different to 10psi from a T88.
As has been said, the only reason people refer to safe limits of boost pressure is on the stock turbo.
Your HKS actuator on the GTRS is a 1bar item so the minimum it will run is 1bar. They run out of puff at around 19-22psi dependent on engine.
But +1 on what ECU are you running? Please don't say stock.
stock ecu pinch.gif as im still not sure wat one to get my tuner would like me to get the vipec ecu.. but i like the Fcons with hand controller :pirate:
maybe even a nistune ?:S
as for fuel pump i ment the 040 in tank fuel pump
the 440 is the inline version
injectors are stock as im going to do them at the same time as the ecu
my plan was to get the gt-rs turbo on run it at min bar ..
get the head cleaned up
upgrade the pump
timeing belt exc
get some forged items in her belly :) do supporting things water / oil pump then once thats all done lookn into tuneing and injectors 2 match
i drive this car f*k all its a long term thing for me
the 040 pump will be fine for the gtrs, the 044 is the external pump your thinking of...
the vipec ecu seems good from all accounts and so is the nistune but the Fcon is harder to find a tuner for Ive heard, if you want a hand controller go the powerFC, but at the end of the day get what your preferred tuner has the most experience with and recommends...
you say you have 'hurricane custom 3inch sports exhaust ( cat and cannon )' tell me you will have a 3 or 3.5" dump as well....
I wouldnt even worry about a pod filter just run the std airbox with a decent hiflow panel filter or an arc airbox... pods are ghey imo.
Im assuming you meant 'cooling pro intercooler'... yeah.? never heard of a pro cool one...
with injectors keep in mind that E85 is around more and more and to run it you need 30% more fuel flow, more power, less detonation more timing...
Yeah ECU first pretty much in all instances.
Without it, forget running more than 7-9psi as the ECU will simply have a fit, not to mention you need injectors.
Have you even read the "what mods to do first" thread?
The RB25 dyno sticky?
You'll soon notice if you read every GT-RS thread, what the minimum requirements are.
yer 3" turbo back
pod was on it wen i brought it was thinking a nice metal fab'd one
and it would be 'cooling pro intercooler' that was allready on it wen i got it too ...
vipec it is i need to sell my bike and it will be done !!!
(injectors will be done wen ecu gets done ) so i will prob drive it like twice after the turbo goes on
i hae tryed 2 look for posts about the vipec but the button wont let me look it wont even find skylines pinch.gif
If your tuner wants the Vipec then go for it. Fantastic ECU and you will not be dissapointed.
Don't worry about half the stuff you listed that you want to do. Get the injectors and ECU done first.
its all done once i sell bike ecu and injectors :)
YZF400 any1 keen :P
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
