Hey guys,
This is one of our open-class competitor in Superlap 2011.
GT Auto Garage R32GTR
post-24739-0-49285700-1306733043_thumb.jpg post-24739-0-19513200-1306733544_thumb.jpg
Vehicle Spec
HKS 2.8L Stroker Engine (Step 1)
HKS Oil Pump
HKS 2530KAI Turbo Kit
HKS R-Type Intercooler Kit
HKS Special Full Piping Kit
HKS Oil Cooler Kit
HKS Twin Power
HKS EVC Boost Controller
HKS SSQVIII Kit
HKS 272 Camshaft & Cam Gears
HKS FCON V-Pro ECU
HKS Hipermax III Super Sport Coilover
HKS Super Turbo Muffler
OS88 6 Speed Sequential Gearbox
NISMO 1 Way Front / 1.5 Way Rear LSD
IKEYA FORMULA Roll Centre Adjuster
IKEYA FORMULA Rear Camber Adjuster
PROJECT MU Billet 6pot Front / 4pot Rear Brake Kit
VOLK TE37 Wheels
https://www.sau.com.au/forums/topic/366046-world-time-attack-2011-open-class/
Good Luck for Superlap, hope that OS88 doesn't have a G in it. Up to you but for Eastern Creek - I would recommend crossover breather from front to rear of the tapet cover!
From your content list I would hit HKS up for sponsorship
Cheers
Stuart
Hey guys,
Vehicle Spec
HKS Oil Pump
HKS Oil Cooler Kit
HKS Twin Power
HKS SSQVIII Kit
HKS FCON V-Pro ECU
VOLK TE37 Wheels
Here's top secret in 10 years track work to keep RB26's together Beleive it or not
Our full trim - rego'd R33 On A050's 1.39.464
1.40's at Superlap 2010
For the cost of your engine it is definitely worth adding.
Has worked a treat on our R32 and R33 and others.
Once again good luck, hope to get there for a look see - will miss running this year, just got too involved with Shannons Touring car
Cheers Stuart
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
