spotted,caught up and had a very quick chat with the owner of a beautiful white stagea. im guessing its blizzerd. :)
sorry didnt reply earlier havnt been active on forums lately, yeah was me, but needs a wash badly and some more power would be nice :)
wouldv'e been you mike, youre dolphin side skirts are very distinctive.
spotted GMG 32R of tonkin fwy last night around 11ish.
Have been seeing a very tidy Bayside Blue R34 GTR with personalised plates around Floreat recently ... hats off to you, it's a lovely looking car
Saw it again this evening at Floreat Forum :worship:
A fk'n hectic white R34 Sedan stock as a rock with 'E' plates on booting it round the cnr of Scarborough Beach Rd/Frobisher st this morning in traffic to cut off a blue Kia. Go hand your license back you cawkhead! (Not that I can believe a judge lets you still drive)
Hi, JiMiH. 'Twas I. It has been a long time since we last exchanged greetings on here - so how the devil are you?
The car has been back on the road for a little while now, with a demon motor built by Garage101 (by Steve Thomas). With a spec list that leaves a crater in my wallet, but a lovely push in the back. How does RB30/26 with HKS V Cam grab you? All very cleverly tuned with a Haltech (by Danny Fisher). Every time I park it I walk away looking back at it!
Maybe I will turn into a pillar of salt?
Cheers. :cheers:
Black 34GTT with china wheels left on the side of manning road fwy exit - RHF damaged
Looked like the same R34 that usually parks it at the bottle shop there. Either clipped turning out onto Manning or maybe boosted into the concrete guards? Was anyone here?
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
