  • Replies 79
Posted Images
You buy it from Amayama's website, which is linked from that Nissan.epc-data.com.
I think these might be the correct part numbers:
1 Nissan B523079972 16.82
2 Nissan B537089940 46.26
3 Nissan B6331AQ000 42.05
4 Nissan B6336AQ000 42.05
1 - relay
2- switch
3 & 4 - lamp covers/shrouds
I wonder what this part is for:
KB6730: バルブ
OEM part numberRequired
per car Production periodSpecCode ExteriorInterior Applies for models Notes Replacements Price range B673089915
See all prices0110.2001 - 08.2004
W.(VQ25DD+VQ30DD) +W.(250TRXF+250TRSFV)[K504]
28 USD
See all prices
is it a replacement bulb?
Edited by ironpaw
Jethro/Dale, did you guys want the entire unit or just the surrounds?
Just the shroud + relay + switch
Which is what I posted above...
I've already got the lamps...
Seems like those lamps are about $300 EACH!!! goddamn...good thing I got them off YAJ
Cam, just the surrounds for me, I think I've found an aftermarket lamp that will fill the bill very nicely; just need to confirm pricing.
Cheers, Dale
while talking about these.
anyone replaced the globes in theirs? its like an HB3/4 plug with an H1 in it. weird!
i wanna HID convert mine for additional awesomeness, but not sure if i should get an HB3 or HB4. i THINK they fitting is the same, from pictures its the actual globe being different - in the halogens.
Sorry guys, no love from Bayside Nissan :(
Part numbers don't come up on either of their systems... let alone a price.
Maybe Craig's "Crazy Skyline Lady" can work some magic.
This was the problem last time I tried, FAST doesn't appear to contain "Dealer Options" which is what the Aero parts appear to be.
FAST only lists the complete front Aero Bumper; $2500, with lights & shrouds & mesh, comes painted, you just choose the appropriate part number.
Tried FTG Nissan who said he'll have to contact Nissan Japan to get me prices.
Emailed the Megazip.ru mob and they're going to gimme a quote.
Also submitted an enquiry with Amayara...
And of course Jess Streeter...
my life is pretty much now complete.
Mate, it's a great look. As they say, you can't beat an original. You should buy it now before all the cheap Chinese knock-offs hit the market.
Can you post up some pics of you camping under the Stagea lean-to for all of us to admire? I promise we will all be jealous :rolleyes: .
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
