Hi Everybody,
have most parts available from a wreck i bought a while back,
All located in adelaide SA, cheap give away or bonus lots with purchases. (does it sound like a haggle co sale????):action-smiley-069:
Car WAS a 2 door manual turbo, with side damage,
have all interior plastic trims, bits & pieces available
dash assy, seats front & rear, parcel shelf, consoles, carpet,
tripple gauges nismo and std,
have suspension, brakes and driveline parts,
exhaust (cat-back) stainless steel
rh clear front bar indicator
LH door assy complete
LH rear 1/4 panel cut
door rubbers and trims
boot lining & carpet
have genuine garage IMPUL side skirt LH side, & damaged front bar (missing rh cnr) in white
also RH side skirt from altia or nismo kit, (not sure)
plenty more, all on racks / shelves.
lets just say $10 for most parts, if you need more than 1 part ill chuck other gear in FREE, this gear has to go,
bigger bits, make an offer or negotiate a bargain
all parts in adelaide and pickup preferred, however will pack & post @ your expense.
pics available of items upon request, have taken alot of pics already.
email or PM for furthar contact detail
"""""neon6 @t adam dt com dt au"""""""
Edited by nat0z
  • Replies 76
Hi Mate.
1. Steering Wheel? Non-automatic?
2. Also, a right side rear reversing light in the bumper bar (not the body) - white. Some R34's have a white light, some have a red light in the rear bar.
If so, some pix will help.
Rgds ... Les 0417 123 053
Hi Everybody,
Whats happened to all chasing the nismo tripple gauges????
any offers that are willing to post cash to confirm the sale? lots of BS from many teen'e bobs maybe??
may just end up on ebay
Edited by nat0z
front & rear???
will post up tonight
nat0
Im assuming the rear seats for the 2 door are the same as the 4 door? If they are then yes.
Im looking to replace mine because front and back are badly stained.
How much are you looking to get rid of them for?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
