  • Replies 41
Swaybars changed my life, I'd get them straight up.
Spacers to give you extra lock cost <$50 so deff get those, makes the steering quicker too.
Coilovers are good too if your budget will allow. (BC Coilovers are good for around $1200)
Shim your stock diff up nice and tight.
500ml extra oil is handy.
Get an alignment too, ever so slight toe in on the back to help keep it predictable and slight toe out on the front to sharpen up the steering.
Tune Agent castor rods are cheap too ~$250, helps the car self steer. But I think adjustable castor rods are illegal for street use? correct me if I'm wrong.
Try and drift with brand new tyres, then you can spend more time out there and less time in the pits changing them thumbsup.gif
My car felt like two bricks connected by some playing cards before I got the cage put in it. While you wont actually damage your chassis by drifting (lol FF) some extra bracing might help tighten it up a little.
Before you do any mods though, just get out there and try it! See if you really like it first! Just give it a go ;)
Tyres... just buy tyres and get some track time.
Don't buy tune agent anything! I watched 2 pairs of castor arms break/fatigue topoint of failure with in 6 laps of a track!!!
Tyres, tyres, tyres...
My tune agent castor rods have done a lot more than 6 laps and I've had many unfriendly encounters with the curbs and they still look shmick as. I'll admit the older ones for the Silvias look like dried spaghetti though.
And yes, tyres, lots and lots of them. I've had good results with admirals. Cheap and they wear evenly right down to the carcass and don't delaminate at high temps. the Federal 595-ss are also good.
Get ready to buy HEAPS of tyres. :D Buy brand new ones though, 2nd hand ones you'll just spend the whole day in the pits swapping them over.
+1 to track time too, any track time is fine, even if it's not drifting, you just need to learn how your car behaves on the track\at the limit.
steering rack spacers are win and cost next to nothing
What are these,where do you get them, where do they go and how do they work..? :D
  • 2 months later...
Where do you get those tierods that you posted simon?
You can get some Tien tierods from Cartel Aus - http://www.shop.cartel-aus.com/Tein-Tie-Rods-Tie-Rod-Ends-DWSS028.htm
I drift with just my stock 32, i just chucked in some tien coilovers and away i went, and it's handy to have good steer tyres. all the extra's just make drifting easier
Diff... welded works a treat
choppies or coilovers if u can afford them... more drift less sailing on the high seas
Seat if your picky...
Fuel
Lots of tyres
A smile for the camera and the pretty ladies watching you
Seems people get so caught up on what is done to all the high end cars and forget to go out and give it a go.
I started in my first 32 years ago with a shimmed diff and a set of coilovers. best time of my life, spent plenty of money on fuel, entry fees and tyres then went and bought a seat and camber arms etc later on as I improved and found the need.
GO SKID
Edited by ti2l
Alright,
I'm curious to see how a stock R32 reacts to sliding so I'll gradually add mods as needed.
This is how I think my priority list should look. I don't plan on buying everything at once or back-to-back so I'll see what the car tells me and upgrade as when I need to.
1) LSD - I'll probably get a 2-way diff as I'll use the GTS-T on the street and welds aren't daily driver friendly.
2) Sways- Adjustable only. I think Whiteline is the only company that makes adjustable sways for the Skyline.
3) Tie Rods - I'll be driving a '89 GTS-T so I'll probably buy whole replacement rods as opposed to just the spacers.
4) Harness (with stock seats) - Cassbo's suggestion. I'll try that first.
5)Clutch- A durable clutch
6) E-Brake- A durability to the E-brake (or upgrade)
7) Tires/Wheels- Brand New sticky tires up front and decent brand new tires for the rear. Extra wheels (maybe).
8) HICAS/ABS- Remove HICAS and/or ABS. I have my eyes on these: http://www.splparts.com/chassis-Z32.html#SPLHCKZ32
9) Suspension- Coilovers and supporting suspension parts.
10)Engine- PS cooler and more HP.
that's a mighty fine list you've got there son :)
Rack spacers should be on there too at #3.
Drift button too if you don't already have one.
Maybe a deep dish steering wheel too so you're not always slapping the wiper\indicators when you're throwing the wheel around. (that's if you have this problem)
  • 3 weeks later...
id be removing hicas sooner rather than later... will make life a lot easier
second hand tyres are fine for the rear... dont ned to be decent to get u started.. 595 or similar up front are cheap and work well
id also throw coilovers a bit higher up the list.... unless ur getting the angle grinder out ;)
u really wont need tie rods and rod ends till much later on, skidded for years in mine with stock tie rods etc.
stock handbrake is great... just get it adjusted
order should be:
Diff
Remove Hicas
Coilovers
skids
the rest can really happen whenever u progress and arent necessities to get you started..... stop thinking and go drive
yeah I've got the 595-evo on the front of mine, they're pretty good :) you want a slight stretch too to sharpen up the steering response. I upped my camber to -4 degrees too, changed my life.
Again, I have let the car tell me what needs to be changed..
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
