so is this wire that youre all cuting coming directly from the brake switch?
similar to andy's theory, just hook the park brake line directly up to the ECU brake activation so the park brake activates it instead
  • Replies 101
Posted Images
This would work fine but harder to implement since you now have to find 2 wires & afaik the handbrake doesn't have a connection to the ECU. Also, the handbrake wire is prob an earth but what is the one we cut? It could well be a feed from the brake lights, ie 12V, so one of it's purposes is to let us know when the brake lights are out, not just kill our launching fun :P .
I think a simple switch to reconnect the circuit is simplest & possibly less problematic in long run. It can be mounted close to ECU (even in glovebox or top cubby near DVD) if you don't want to run wires across to driver's side.
+1 on that.....I ran the momentary switch down in the slot below the Cig lighter.
did you notice a difference in drivability at all though craig?
assuming mines shown a light i dont think ive noticed any change at all
nup....noticed nothing...nothing at all!....could still do a stall and launch at 20PSI bagging all 4's right through 1st!
yeh i dont think im gonna bother with a switch..
my AFR's seem fine, i havent noticed any drawbacks over the past few weeks ive had it.
i have noticed the car seems to be pulling alot harder, but thats probably coz i just serviced it.
meh...
whats your stall at?EDIT: actually whats everyones stall at? if they were to sit on the brake and accelerator, what to the revs read(before spinning)
at 3000rpm I cannot hold it any longer.....I have to let it go....that's at 19-20PSI.......if it's in 2WD I need to let it go a lot earlier!
yeh mines at around 2500-2700.. my tires wont spin up at stall even at 10 psi.
if its when or really cold we have another story but that might be the brake bias or the pzeros
Jethro, can you confirm and let me know.. i have a feeling all(some) the stall converters are varied now..
Yep, around 2700-3000rpm, mine is slowly churning both rear tyres and sliding the back end to one side in the lane. LSD FTW!
Let it go; solid chirp and it f**ks the f**k off out of there!:banana:
do you have four pot fronts?
Too many projects going on ATM, will have to get back to my Big Brake conversion soon. Do have to stand on them fairly hard too, and no wire snipping yet.
I'd certainly like a bit of Jetwreck's turning all 4 in first though...
Edited by Daleo
Shouldn't make a difference from standstill should it?
yours wont because you have rears..
but the brake bias changes with the four pot fronts(mainly GTR32 conversion)
I think anyway.. im sure cam will come and correct me.
looks like it will make it easier to spin up the rears at stall as you dont have to stand on the brakes as much to hold the front.
Aaron try this.
Stall up in 2WD......when it starts spinning let it go and then flick your attessa back on and it should lock up the fronts launch like a mofo!
I did a couple of back to back tests with a mate the other night on a private road and this was by far the quickest way to launch my car.....sub 5's!
Edited by Jetwreck
dont have a switch yet.. and surely thats not good for the attessa system right??
and as i said, these tyre will JUST start to slip but wont spin at stall, they're still new and really soft and sticky.. sometimes i wish i had nankangs lol..
i reckon i'll get em spinning once i do the brakes, i wont have to stand on em as much
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
