Hey guys might be a bit of a noob question buut the other day I was driving and managed to here a grinding noise when shifting from 2nd to 3rd. I think it was because I wasnt concentrating and the clutch was not all the way depressed. It was around 3500RPM and lasted about 1 second
Have I caused any damage to the box or syncros by doing so. Is it worth changing the tranny oil or?
Never have done this before so I am not quite sure.
https://www.sau.com.au/forums/topic/368063-gear-grinding/
I probably do that a couple of times a year due to brain fade. Its only worth changing the oil if its due for a change, or if you don't know when its due for a change, so you do one as a precaution then get back to the normal drain interval.
https://www.sau.com.au/forums/topic/368063-gear-grinding/#findComment-5870200
Will be fine mate. Too much of it will wear out your synchros though. That sound you heard was the dog teeth grinding against each other because you hadn't clutched in properly. Unless your synchros start making noise regularly on gear changes you have nothing to worry about.
https://www.sau.com.au/forums/topic/368063-gear-grinding/#findComment-5870259
Ye temporary brain fade...
I didn't slam it in, as soon as it grinded I am pretty sure it went back into neutral and then I put it into 3rd again.
Reason I asked was I thought there might be some metal shavings in the oil and well its never happened before so I didnt know what damage I had caused.
https://www.sau.com.au/forums/topic/368063-gear-grinding/#findComment-5870433
if there was and metal shavings, it would be bugger all, especially when you remember that there is a few litres of oil in the gearbox. secondly, i'm pretty sure the drain bolt has a magnet in it to collect any metal shavings to stop them doing any damage.
https://www.sau.com.au/forums/topic/368063-gear-grinding/#findComment-5870818
cleaning the teeth grinding - take foot off clutch a little too early and hear the clutch teeth give a squeel.
hard grinding - crunching sound..
Well It wasnt like a crunch squeel more like a grinding i guess. I cant describe it really.
It is identical the sound first sound at 1.32 of this video.
https://www.sau.com.au/forums/topic/368063-gear-grinding/#findComment-5871356
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
