1: PWR R32 GTR radiator the end takes are 70mm thick and the core is 57mm thick. Used to start the car and then it was removed because I wanted to try a standard radiator. Standard shroud fits and the radiator goes straight in.
$500
2: Autobahn hard piping kit for R32/R33/R34 GTR skylines. Includes T bolts and longer silicone joiners which I got from Plazmaman.
$250
3:OS Giken Twin Plate clutch and flywheel from a 300 ZX, needs rebuilding.
$100
4:Full Set of R32 GTR rotors and pads
Front discs are 31mm thick, pads are 5.5mm thick
Rear discs are 17.5mm thick, pads are 10m thick and look pretty much new.
$150
5: Blitz R-VIT Type II - connects to the consult port, %100 working
$100
6:the thing that gets Jap radios working in oz (band expander)
$5
7: R32 GTR white rear wing, fair few nicks and scratches, needs touching up
$50
Pick up from Quakers Hill after 6pm and weekends and pickup from Wetherill Park during work hours.
Items can be posted at the buyers expense.
Josh
https://www.sau.com.au/forums/topic/368185-r32-gtr-parts/
Did the hard pipe kit fit perfect? Any mis matched pipes etc?
The kit fits with longer silicone hoses I bought.
pm me your number
i'll take the wing and radio expander
Got your message, will call tomorrow
Pics of rvit
Pic is already up
https://www.sau.com.au/forums/topic/368185-r32-gtr-parts/#findComment-5872083
Also for sale:
1: Whiteline? front strut brace, just needs a good polish, used.
$60
2: Apexi "pen" turbo timer
$40
3:RB26 standard rods and pistons, in good condition.
$100
https://www.sau.com.au/forums/topic/368185-r32-gtr-parts/#findComment-5872602
  • 4 weeks later...
  • 4 weeks later...
$450
2:OS Giken Twin Plate clutch and flywheel from a 300 ZX, needs rebuilding. Was quoted $800 to rebuild. It has sprung friction plates which are 218mm in diameter and a pressed steel cover with 2 diaphragms in it. That is all I know about the clutch.
$100
3: Whiteline? front strut brace, just needs a good polish, used.
$50
4: Apexi "pen" turbo timer
$40 includes postage
5:RB26 standard rods and pistons, in good condition.
$90
6: Silk Road Fibreglass Front diffuser for a R32 GTR
This will also fit a GTSt, but if you're running a standard front bar you will need to modify the attachment hardware to raise the height, to match the bar.
$250 includes postage
Pick up from Quakers Hill after 6pm on weekdays and and anytime on the weekend.
Pics are at the beginning of the thread.
Josh
https://www.sau.com.au/forums/topic/368185-r32-gtr-parts/#findComment-5984905
  • 3 weeks later...
$100
$50
$90
7: R32 GTR Exhaust 3" mild steel and quiet. No holes or dents. $100 (pickup from Wetherill Park only)
8: R32 GTR front pipe. The usual Y shaped pipe. No holes. Has an O2 sensor bung in it. $90
Pics are in Post 1 ,6 and 20
Josh
Edited by dontfeelcold
https://www.sau.com.au/forums/topic/368185-r32-gtr-parts/#findComment-6022700
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
