Hey
Long story short, the car span 180 degrees and hit the curb on the passenger side maybe about 20km (was traveling under 60kms and was braking for a long time during the spin) bending the tire inwards (lowest part of the hub pointing inwards toward the engine) while I had the wheel turned right.
All I can see is this damage.
(sorry its upside down)
What is this part called? What other parts may be damaged and need replacing? Car is a r32 gts4
Thanks in advance!
Also make sure to check your hub isnt bent aswell. When I smacked my rear control arm thought that was the only problem replaced to see still probelm there when had closer look the hub had twisted and deformed.
I would change that caster rod too. Most likely the rose joint is damaged now due to the impact.
I would also check the steering tie rods, and tie rod ends for damage, as sometime massive shocks like that "may" fracture the tie rod ends
yeh my mate has done this to both of his front wheels, also not drifting on a street, both times we changed the control arm and castor rod, and some how it worked that no alignment was needed, just lucky i spose,
