  • Replies 60
Been looking for a clean unmolested 94 32gtr for a while, im not saying yours is but to get it there ill need to spend time and more importantly money to freshen it up or at least match the body kit colour to the rest of the car as well as freshen up the interior. Especially it being a 94 V-SPEC 2 it should all be kept in immaculate condition. I like that I'll get to see it all done myself as I tend to keep my cars long term.
I've made some calls and so far I'm looking at $3000 for a respray to match everything, and either $600 for a clean set of 32gtr seats or $2000 to get r34 gtr seats (haven't decided yet). If the timing belt hasn't been done I'll be looking at replacing it then getting other belts, bearings and seals done for peace of mind, and considering its a 200,000km+ motor a head recondition would also be a good idea.
I'm not including the cost of the dash and other interior bits because these things are expected of a car with this amount of km but I do need to consider the rest - money you're asking Id expect it to be in immaculate condition. I'm sure you understand this.
Hey mate, I don't know what your talking about in getting the body kit colour matched, it's the same colour already. If you want to get new seats that's your choice, the only one with an issue is the driver side one and it's very minor. All belts and fluids were done just before 200,000km (had it's major 100,000km service done then, have receipts) so you don't need to do those. Basically at the end of the day if you want to do all that stuff, that's fine but that is your problem and not mine. If you don't like the price and you expect an immaculate VSpecII for $17000 then go and find one somewhere else.
I'm getting sick of having to come in here and deal with these sorts of posts. I shouldn't have to. The rules clearly state if you don't like the price then don't comment on it. Use PM, that's what it's for.
Ok enough reporting - Joe's post is not out of line, unlike the others who've been dealt with.
Joe is simply going over the estimated costs to get the car to a certain level which is based on the information / pictures you've supplied based on what else is currently on the market.
There is a point of being reasonable here.
  • 1 month later...
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
