evening all,
looking at upgrading my AV in the comming weeks. and on the lookout for a new spyware aswell.
currently running AVG free/ Ad-aware / malwarebytes, but AVG its getting a bit sloopy, and i've had troubles with ad-aware detecting game files as spyware.
so i'm curious as to what everyone is using and their opinions of them are.
https://www.sau.com.au/forums/topic/368515-anti-virus-spyware/
I use Symantec Endpoint Protection (would not touch any norton / symantec consumer product) and Malwarebytes.
For a free AV, I've seen AVG let too many things in and alternately find too many false positives on computers I've fixed, don't mind Avira / Avast though.
Microsoft IMO have the best product out in terms of invasiveness - it simply isn't :)
Microsoft Security Essentials. Been using it now for 18 months without an issue. Auto updates, auto scans and best of all it is not a CPU hog. I can happily use on my PC with it fully activated and running scans and notice no impact.
Also uses the lowest resources of most free virus scanners.
It also integrates with MS Security centre on your PC and doesn't overlap etc. Never had a false negative, never had it stop me from doing anything but then i do use my PC as an Admin given I'm Win7 Ultimate.
Recently my brother actually had issues with AVG IIRC, it was stopping his utorrent client intermittently for some dumb reason. Soon as it was removed and replaced with MSE - problem gone.
i run nothing so far i have found that to be quick and effective ;)
i don't go looking for cracks of any sort and i don't bear-share or any of that crap i don't click weird links in emails or msn
your obiously not looking at enough porn. :P
your input is much appreciated guys :)
I ran nothing for the best part of 4 years simply because everything else was too intrusive/took up too much resources etc.
Hence I went with MSE once it had a bit of market penetration/review etc.
You can watch porn till the cows come home and not get a virus. You could click a kiddies site and get one.
It's all about the sites you visit and then the links you click.
I run PeerBlock with full lists activated as well which is also a very good compliment.
Still lets me use SAU, Facebook. Only common site i use that it blocks is GMail/Google searching. But you can just cancel specific lists if it gets too intrusive.
MSE is not an enterprise product though, its for the average joe home user. Not a company that is prone to far wider and more dangerous attacks.
If an organisation did as such, then they are simply retarded and deserve it.
TBH i don't trust any.
No anti-virus will ever be 100% fool proof though unless you have total lock-down which then allows users to not do a thing.
My workplace is semi-like that and no word of a lie, when the scan runs daily, you cannot use the PC for an hour due to a crap implementation.
So I just pull the plug and reboot it lol. The scan isn't intelligent enough to realise it never finished (our desktop guys make me laugh almost weekly) ;)
End of the day anyone relying on anti-virus as a home user to 100% protect them is kidding themselves as no anti-virus will protect you from clicking a bogus link in an email/website.
Yet most average users assume this to be the case unfortunately.
The more invasive a anti-virus is, the more it will piss you off and you'll end up cancelling the alerts so often that you'll be caught out anyway :)
Has anyone ever thought that it's maybe the antivirus companies that create many (not all) of the viruses?
I'm with Madaz on this. If you know what NOT to click and which programs to execute, then you won't find a problem.
I was having more problems whilst using antivirus than not.
That being said, I don't leave my PC on 24/7 to constantly run torrents. It only gets turned on when it's being used.
Outpost Internet Security Pro on the home PC.
Have run it for a couple of years now and found it to be better than anything I had in the past.
MSE at work.
[quote name=ClutchBurndout-:(' timestamp='1308706438' post='5877233]
i havnt had any antrivirus on my pc in ages
but then again i dont go visiting hardcre gay porn sites like the rest of you
So you say :rolleyes:
+1 for home use. lovin it.
SEP11 for enterprise though as was stated by other people.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
