What - Various r32 gtst skyline and other parts.
Location - Brisbane, close to city.
Contact - Pm me here or Msg my phone 0432227533
1. Set of R33 GTR Wheels (17x9 +30) with 235/45 Maxxis I pro tyres with 40 to 60% left. 2 are coloured original silver and two have been painted gunmetal grey. All have centre caps. Fair condition some gutter rash. Can paint all wheels same colour at extra cost.
$1000 neg.
Photos to appear soon.
2. Tein super street coilovers to suit r32 gtst. Bought second hand but still in good in very good condition. Softer spring rates and valving for aus conditions. Currently fitted to vehicle photos can be provided.
$1000 firm.
3. KYB Shocks and super low King Springs. To suit r32gtst. In excellent condition. Under 5000km of use.
$650 Firm
4. Standard shocks and lowered springs in used condition. Shock are old, spring are quite low. More for looks than performance.
$50 neg
Photos on request you prob know what they look like.
5. Pair of Riverside 3 piece wheels 16x8 +1 offset. In used condition. Some scratches and bumps. Still hold air and balance up perfectly with weights. 5X114.3 only.
$400 with legal tyres and $300 without.
6. 6 x R32 Gtr injectors 440cc. Bought never fitted. Cleaned and flow tested by injector specialist.
$250 neg
7. Forward facing plenum to suit RB20det. Made using additional alloy. Not simply moving throttle body. Doesn't come with throttle body or IAC valve.
$300 neg
8. Sparco bonnet pins silver in colour. Still in plastic.
$40 firm
9. RB25 cam covers in reasonable condition.
$40 neg
10. Standard r32 5 bolt viscous diff with 4.1 gearing. In good condition +100,000k old. Suit shim or after market centre.
$100 neg
11. Standard RB20det turbo in good condition. Done +100,000km Comes with 90 deg outlet and standard actuator. Removed due to upgrade. Suit hi flow etc.
$50 neg
12. Hybrid copy FMIC, selling due to upgrade, previously repaired. Holds air fine
$50 neg
13. Replica R32GTR spoiler gunmetal grey in colour, with working led brake light attached. Could do with being repainted.
$ 150 neg
14. 12 inch kicker sub, was working when removed from vehicle
$20/ offers?
15. RCI brand large size helmet. Far too big for my head, needs good home!
$50 neg
16. Various standard r32 parts, drivers seat, standard sway bars, castor arms, r32 shifter and stereo surround with ashtray.
$ offers?
Pictures if required, most of you will know what this stuff looks like.
Edited by Kisuu_Buta
https://www.sau.com.au/forums/topic/368797-r32-gtst-and-other-parts/
  • Replies 117
  • 4 weeks later...
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
