  • Replies 117
More parts for sale!!!!!
***R32 GTR drivers seat in average/good condition. Normal wear on edge of the seat. Small cig burn in the centre of the cushion see pics.***
$280 Firm. (Will swap for a passenger seat in same or better condition)!
***R32 GTR/GTS Half cage. Doesn't come with any base plates or bolts, is also missing the cross bar. ***
$350
*** Blitz electronic boost controller, (solenoid and wiring not pictured). Never fitted to the car, display works with power connected. Using a simple bleed valve so I have no use for it. ***
$100, so cheap!!!
*** Set of 4 - 16 Inch Rims, Guigarro design brand 2 peice in design. Sized 16X8 and 16X8.5 (exact offsets between +35 and +45. The offsets marked on the rim may be inaccurate if the wheels have been seperated in the past). Good condition, only two have centre caps.
The 8.5's will not fit on the back of a R32 gtst (without spacers) because they foul where the hicas tie rod end attaches itself to the rear kuckle. They also will not fit the front because the front calipers are to wide.
$400 (No tyres)
Some of the pics look strange, may have broken my camera...
Edited by Kisuu_Buta
  • 3 weeks later...
  • 3 weeks later...
Tein coilovers, R32 GTR Seat, R32 GTR injectors, 16 inch wheels (2 different styles), R32 half cage, blitz boost controller, RCI helmet, King springs/kyb suspension. ALL STILL AVAILABLE!!!
***HEL Oil Cooler Kit from the group buy is now for sale. Cost $450 will sell for $400 posted (Only east coast). Never used, only opened for inspection. Grab a bargain***
  • 3 weeks later...
  • 5 weeks later...
How low do the springs on the standard shocks go roughly? Im just looking for some low rear springs, so keen for the super lows! ... tyrna bargan hunt lol sorry just really need to do full engine tune first :/ and im in victoria :(
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
