Ok need some help on installing my sparco 4 pt harnes.
Just wona know were people have mounted the eye bolts so that it complies with cams.
Was going to use the stock seat mount points for the sholder strap and r/h lap strap and drill in to the tunnell for the left hand strap.
the other thing is i wont them to be easy to access to so i can remove it when not in use.
pics would help.
thanks brentt.
https://www.sau.com.au/forums/topic/368910-mounting-4-pt-harnes/
You should be able to use the factory location for the side straps on each side.
The shoulder straps on the other hand won't meet CAMS requirements if you use the rear seatbelt mounts, it is too far down. The safest place to mount them is at parcel shelf height, but the parcel shelf itself is not srong enough. Best idea is to buy or make a "harness bar" if you don't have a rollcage.
  • 4 weeks later...
I am 184cm tall, and I have adjusted my seat to a decent distance from the steering wheel, not like a Chapel street cruiser, and the angle from the seat to the rear bottom seat belt bolts from the horizontal is 38degrees - and CAMS states a maximum of 40deg, and with 0-10deg being a recommended range.
If a driver is shorter chances are his seat will be even further forward, hence the angle will be less than what I have.
Edited by rehab2010
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
