Now you mention it I think I did once see a pic of one of their housings .
Flange adapters are a pain and from memory the GT28 turbine housings have the flange and throat section offset with the volute for packaging reasons . Could potentially screw up and have wastegating issues with adapters .
The other half of a GTRS or GT2835 KAi is the port shrouded compressor housing and it woulde cost something to re create .
The upside of the larger AR turbine housing is it would slow the turbine down a little and offer a bit more exhaust throughput - maybe something like 20% but thats a pure guesswork going off the turbine map differences .
If you feed guesstimation into the Tardis computer does it reckon needing 20% higher revs t get it going ?
Woolverine would it be good or bad having a GTRS start boosting 400 odd revs later , what eventual difference did you find between the GTRS and 2835 Pro ?
A .
It occured to me to go back and have a look at Garretts turbine maps for 0.64 and 0.86 housings on that GT28 turbine and the difference is a little better than I thought .
Have a look at the flow rates of the GT28 0.86 AR and te GT30 0.63 AR .
http://www.turbobygarrett.com/turbobygarrett/images/catalog/Turbochargers/gt28_images/739548-1&064turb_e.jpg
http://www.turbobygarrett.com/turbobygarrett/images/catalog/Turbochargers/gt30_images/GT3071R_turb_e.jpg
Interesting that the GT28 turbine in its larger housing slightly outflows the GT30 in its smallest housing . Hmmm .
Doesn't surprise me really when you consider that HKS custom optioned a 3071 with a .68 rear to make the 2835 pro s
I have driven both and would urge anyone to spend te extra few dollars on the 2835 pro s. In my car I have 18psi by 3350 on the dyno in 4th.
On the street/track it pulls like a freight train all the way to redline with a super constant surge of power. On the track it is just all power all the time as any lag you might feel is negated by the higher revs.
I found the 3076 .86 to be too big for the 25 and the gcg/gtrs to be just that tiny bi small, with the gtrs being much more fun than the Garrett.
I can't comment on the 2835 Kai as I haven't driven one biut I'm sure it will sit somewhere in-between the gtrs and the 2835 pro s. My guess is that if you can stop it surging then it might just be the best overall option.
HKS do their research on actual RB25's and the pro s' massive powerband, huge top end and blistering response is testament to this.
Food for thought
A .
They don't look worlds apart on the dyno down low and on the ramp to boost but on the road they feel very different.
It certainly don't think a housing change would equate to 400rpm difference or at least I don't think it will feel like that once you push some more timing to fill in there to fill it in.
The problem I think with the GT2835 KAI is with the anti surge slots. Stao from Hypergear PM'ed me about it and after explaining to me the theory behind the anti surge slots and how it could affect the power etc, I thought I would try a cheap fix for now so I came up with this:
Now after I put this on the car went pretty fuely under boost, i expected it to go lean if I'm honest but anyway. I spent about an hour tuning the AFR's to be a bit better (still a bit on the safe side but dont want to push it to hard yet) and played with maybe 2 or 3 cells of timing (under load)
I have knock sensor issues ATM which is why I havent added timing in. They give rediculous readings and I never hear a hint of pinging from the engine.
Anyway, Conclusion from the front swapover - The turbo seems to boost a bit smoother (if that makes sense), drive better, I dont have the "surge" issue I was talking about anymore, and I managed a faster 1/4 mile time and MPH last time I went for a race. (13.0 @110MPH, although I think its easily got a 12 in it if I get a bit more practice)
I managed 245rwkw with the old front, I'm waiting till I have some time to throw it on a dyno again to see if the front has netted some improvement to the power but from the feel of the thing I'd say it is better. Also the front is not sealed from the rest of the turbo. So I assume the high pressure from the anti surge slots that are now blocked may be leaking to the outside of the turbo(not to mention the possibility that this is causing turbuelence)
As I said however, This is a cheap fix and if it nets a power gain I'll be getting a proper front housing for it without the anti surge slots, A Pro S housing would be ideal
Between Garrett and HKS neither really got it right with GT28 based turbos for RB25s . I get the feeling that back in the early days more emphasis was put on catering for RB20s than 25s and thats possibly why HKS had a GT28 IW turbine housing made with the T3 and single turbo Skykine outlet flange in 0.64 A/R only .
I'm 99% sure its the same one used on 2530s and 2535s for many years now and the chances are slim of them doing a 0.84 AR one now .
I think I'll just leave it as it is (GTRS)and save the involved mods for the Lancer , I want to lose the AYC for an RS clutch LSD rear end . 240-250 in the Skyline is fine for me .
A .
Just adding my 2c more for clarification as I have been seriously considering the GT-RS for a while now. People saying the GCG highflows are comparable...? From sheets in the RB25 thread, the GT-RS seems to be pretty comfortable at full boost by ~ 3000rpm (for average of 240kW ~16psi), I put a GCG OP6 highflow (though it was journal bearing, but most are) on a mates R33 and it doesn’t see full boost until roughly 4000rpm. It makes a great figure and holds boost (260kW @ 18PSI) but that's just 1000rpm too late for an aggressive streeter imo; or is the comparison more for R33 highflow jobbies (which are also ~ 230-240)?
GCG hi-flows are ball bearing.
Back to back test OP6 housing vs GT-RS same dyno, same car, so I can only report what I saw on the dyno.
ps. I am talking where power was made and they track pretty similarly. The GT-RS had the edge and there wasn't anything like 1000rpm difference in boost threshold.
  • 4 years later...
    • You're not the first person that's said that about this car lol. A Touring wagon GT in Spark yellow mica would be the dog's danglies 😆 I will keep an eye out for a future purchase for sure. The seats are almost like the OEM Recaros... electric adjustment for fore/aft and tilt movements except reclining.
    • Yes!! I love these! It's a shame its not the wagon though!   Thank everything that's holy that it doesn't have the interior of the Aussie delivered ones. Those seats are so much nicer.
    • I'm both sorry and thankful that you do that.
    • 2001 BE5D Subaru Legacy B4 RSK (3rd gen) EJ208 (pink injector) Twin Turbo 280PS 5-speed manual Full time 4WD "RSK" grade which means all of the above LQC option which means stock rear spoiler  I got it primarily to export to someone outside Japan who was interested. These BE5 Legacy B4 RSKs are going through a bit of a resurgence right know in Japan as they are one of the few cars from the "turbo, manual, RWD/4WD, 280hp gentleman's agreement era" cars that don't require stupid money to purchase. Which for some people might be a good opportunity to get as a base for restoration. If I can't find anyone to purchase it I will certainly be doing that myself over the long term. Why? Because it's properly fast in stock form, handles well enough for a GT sedan, there's still enough aftermarket and (if you can wait a while) genuine part support to make it a restoration candidate (<-- that will only get worse over time so it's a case of do it now or choose get a BL5 4th Gen). Mechanically it's fine, has only 89,200kms on the odometer. The problem with this car is that the body and exterior trims are weathered from at least the last 10 years being parked outdoors. I'm the 3rd owner, the first owner was the one that had it for 14 years and barely drove it, had a low-speed front impact (which didn't damage anything behind the radiator support) and got it fixed and sold it. The 2nd owner put most of the kms on it and parked it outside for the last 10 years, hence the door rubbers have seen better days but if you overlook those cosmetic details, it presents pretty nicely. There is some minor rust on the LH rear wheel arch which I'll have looked at too at some stage.  Also as you'd expect from a car this age, the clear top coat is gone, leaving a satin finish on the roof.  Mechanically it's fine (as you would expect from a car with less than 100K kms) but the steering does feel slightly vague around the centre position at higher speeds. So first on the list is to get the steering rack bushes looked at. There's also the Lock button on the remote which doesn't work, but the Open button does.... it means that the anti-theft system thinks it's always open? It seems like if you open the car and don't start the engine within 3 mins or so the anti-theft kicks in again without any beeps or signals. So if you got to start it after that, it won't. You have to push the open button again. That's how I understand it anyway. Just a small irritation but not a big problem to sort out. There's only one mod, the Wangan SPL muffler. Just a tad louder than stock. It's a really good mod for those who don't want to wake the neighbours but still want to hear a more prominent unequal length header EJ20 sound. Anyway I hope to get all those things done eventually, that is unless someone wanted to import it to their country from Japan (where I live). I'm open for negotiations as I really would like a Skyline... but this will definitely suffice in the meantime 🙂 *Disclaimer: This is how I picked it up from the dealer, minus the stuff on the back seat. I haven't cleaned the engine bay or done a thorough exterior clean, aside from spray painting the wipers.
    • Wow, even with the Audi logo centre caps. I love OEM wheel mismatches.
