What car was your first taste of boost in??
Mine was in an S13 CA18DET Silvia. At the time it felt bloody quick!!! Me and a mate were thinking that it wouldnt be much faster than our N/A r31's LOL.
I would love to experience how quick a GTR feels!!!!
So when and what was your first ride in a turbo car??? and what did you think of it???
Cheers
https://www.sau.com.au/forums/topic/36937-your-first-taste-of-boost/
  • Replies 58
1st taste of boost was in my mates 180SX totally stock then when i worked my ass off got myself a 32 OHHHHH BABY it was like heaven on earth..... but laster that week the devil (cops) rained on my parade.... it was worth it!
only ever being around N/A cars as i grew up i thought the vn ss was quick but when i had my first taste of a 11 sec vl turbo i think i had to be revived in the back seat, such a rush and ever since then, i personally, dont know how i wont want to own a car that isnt turbo!
my mates S14a 200sx put me in my seat. he's like "Still think only milk and juices comes in 2L?" my kingo at the time had a 4.2L V8, and it had nothing on the silvia. Thats what made me decide on a Skyline, because i just can't go to 4 cylinders...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
