anyone with M35 has bought any reinforcement braces (not sway bars)? if yes, do they actually improve handling or at the least work as it's supposed to?
something like this: http://www.oxmotorsports.co.jp/7.html?
Iain has em on his car....pretty sure he was happy with the result....although we did do the BC + Sway bars at the same time!
  • Replies 193
Posted Images
i have them
and yes they help. well, i assume so.
i did them, swaybars and coilovers all at once.
anyway the chassis creaks less now when i go in and out of my driveway at an angle...........
is that actually chassis flex?
i assumed it was just the movement of the swaybar. and the creak was nil lube in there.
are they actually the same as the whiteline sway bars in dale's group buy? i'd like to get the front and rear strut bars, but are the others sway bars or additional braces?
completely different!
the bracing stops chassis flex and adds rigidity. the sway bars prevent body roll.
get both, failig that, just get the swaybars
of course, its metal!
jack up one corner and open a door
my car creaks when i park on uneven surface and climb into the rear seats from 1 side
i thought it was swaybars that ran out of grease or just worn bushings
speaking about creaks, my car creaks a lot on turns and even when rolling slowly on a slightly uneven surface...is it normal or something that i need to look at?
old and dry bushes is probably all it is. unless your car is doing something weird, i wouldnt worry too much about it.
mines done it since i got it. i thought changing the suspension and swaybars would fix it. but the creaks are coming from elsewhere. maybe ill throw some lithium grease around one day
guys, more questions
1. i saw a DIY 1 day on changing the shifting direction for the manual but can't find it anymore, any links and photos on how to do it?
2. looking to change brakes, i know there are a couple (or more) threads for brake upgrade, but just want to get a quick and straight answer: does R34 GTT brakes (f&r) fit M35 and what do i need other than the caliper and corresponding rotors and pads?
3. anyone know how to raise up the HID headlight beam? i need to raise up the left one as it's not as high as the right onepinch.gif
4. continuing on the headlights, anyone know what bulbs we're using for the HID and also for the other light (the yellow one)? thinking of getting a super yellow light and a higher K HIDwhistling.gif
1; http://www.skylinesa...5+shift+reverse
2; Fronts will go straight on; rears as far as I'm aware no one has tried. V35/Z33 brembo rears will.
3; There will be a manual trim adjustment; I would suggest removing the bumper skin and removing the headlight itself; easier than trying to muck around in the engine bay. With a little practice you can remove the bumper skin in less than 10 minutes.
Also check that the adjustment servos are both working; this could be the root cause.
4; 4200k D2R's are factory , so you could step up to a 6000k without going too silly. I believe iamhe77 is using 90/110w halogen globes in the high beam slots with no added relays; with no issues.
Edited by Daleo
I'm all over it Aaron :thumbsup:
and D2's for the xenon. lol replaced my $50 cheapys after two years. cant beleive they've lasted.
Edited by Daleo
i accept my fail lol.
whats wrong with 8000k? lol yeh you cant see very far but meh i dont need to see 1 km ahead of me.
Too blue; light doesn't seem to throw very far and glare reflects back at you off every road sign in the known universe.
That and you look like a stupid teenager with an Excel and some Ebay HID's yo!:yucky:
Edited by Daleo
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
