72 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I have found that if I do put v-power in the Gtr feels a little docile, but I have also since found that the exhaust cam was buggered and timing was all over the place.. The clincher for me was a mates 180, he is running about 280rwkw on standard cams and valve train, and is one of those freaky natural mechanics who just gets cars, he has found that v-power tends to foul plugs more than anything else, there were 1 or 2 other issues, but I am not sure what they were, so I won't make claims. It is always ultimate for me
  • Replies 40
As has already been said... 98 is 98 and the most likely reason a car loses perfomance on a 98 fuel is it's probably stale from sitting in the servo's tanks for longer than usual simply because there isn't enough people using it quick enough. If you buy your 98 fuel from a servo that would sell a lot of it you can bet it will be as good as any other servo's 98 fuel. It is hard to know which servos go through enough 98 to have to keep topping up with fresh fuel but thats where it's hit and miss.
ahh, there's no crap to suck in, there's a sock that covers the fuel pump no? and either way, the pump is at the bottom, so crap surrounds the pump whether at high or low levels.
but running the fuel level low might introduce bubbles into the system
Topic has been discussed a billion times.
I would say the best fuel would be any 98RON fuel from a Caltex/BP/Shell/Mobil petrol station that is usually very busy; which means fuel supply has a high turnover rate.
Can't remember where i read it, but someone mentioned BP and another brand of petrol comes from the same refinery.
Edited by sloutch
you will be sucking crap from the bottom of the tank no matter what, it's just that when the fuel level is lower the conecntration of crap is higher, that said, if you run your tank low a few times in a row then you will have sucked up a fair bit of crap and most of it will end up in your fuel filter, so it won't be so much of an issue down the track. that said, everytime you fill up you would also stir up any crap at the bottom of the tank and to a lesser extent this also happens when you drive over rough roads.
I always get Caltex 98, but only because it's the most convenient for me to get to.
To be honest... I've tried 95 and 98 octane from several different retailers and not really noticed any difference in performance.
george, you do realise you a wasting more fuel driving around?
Of course, but being a cheap arse Asian every time if I do go to a further away station I did the math using my car's average fuel consumption (12.5 - 13.5L/100km), the extra fuel it will use going the extra kms to that station compared to the closet one, the estimate amount of fuel I'll be putting in and the extra cost minus the difference in fuel price between the stations & overall if there is still a net saving I will go, otherwise I will go to my usual Caltex near Osborne Park.
BTW, I not sure if the other states have it, but the WA government have fuel watch website where it lists all the fuel prices for today & tomorrow so I use that to get all the prices of the main servos in my area before I do the math.
the missu and I kept having an argument over fuel in her honda, i kept telling her to put bp ultimate in it but she doesnt want to listen and keeps putting 91 or e10 cause its cheap and aparently all the same, so i made her do a little test..
Filled it up run till the light come on..
BP ultimate 550 kms on i think was 55l..
E10 did about 450km for the 55l...
With the price difference in the 2 km per dollar was almost identical didnt bother testing 91 yet. Cause i dont use it but i will do that test next for curiosity sake but i expect to get around 500km
But it just goes to show there is no reason not to run premium fuels as the extra mileage makes up for the extra cost and buying a fuel on price alone is naive..
i actually prefer to run e10 in her car for its cleansing properties but if I take a long trip I use Ultimate for the extra mileage...but it really doesnt matter..I would use BP all the time cause it definately makes more power but that means argueing with a woman so I settle for e10, i dont drive the thing so who cares
Of course these tests have nothing to do with power..for power In my 33 I believe BP ultimate is the best but I do like Vpower as well it feels snappier and more livelyy under throttle though probably not as fast as BP..
i did a similar test in the missus SSS. this wasn't just 1 tank either. i ran each different fuel for a few months so that i could rule out any possibly differences from driving style, terrain or trip type, because basing your results over 1 tank of fuel isn't a good idea and could see you wasting a lot of money for no reason in the long run. this was based on 2 different 98 fuels, 2 different e10's and 1 91 octane. the difference between them all was much less than 1L/100kms. i've done similar tests in other cars i've owned, but generally only for a few tanks rather than for a few months, and always had similar results. with the price difference being about 10% and the fuel savings generally being below 5%, it isn't worth it in my situation.
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
