  • Replies 161
Posted Images
Nice! About time I had a fellow Stagea driver in this section. Welcome to the forums, and welcome to Stagea ownership. :D
alan_key - Do you live on the beaches? And have you been looking at The-Lowdown lately ;) Turned out good! Maybe use another flash on camera right for some more fill and to kill the shadows?
Yeh i live on the beaches. and haven't heard of that site till now, seems like they've been using that spot too ha. Nice rig shots, wish i had a decent rig
Edited by alan_key
During my lunch break yesterday, I snuck down to the creek to find out what was making all the noise.
Oh yeah... found out that some of my V8 shots from clipsal will be used in the Bisley Workwear catalogue coming out soon too :)
I live on the Beaches too Alan. If you see a white evo 8 MR driving around give me a toot! :)
Will do!
MaTBoy nice shots, just wondering do you use a monopod or tripod when you're panning? last time I just did it handheld with IS and was getting pretty inconsistent results, either i just need practice or im doing it wrong ha
I never use a monopod unless i'm holding a 400 2.8 or 500.
Turn the IS off and practice your technique more. Panning is all about technique. Unless you were shooting stupid shutter speeds below 1/15th. I'd recommend starting at 1/100th, get consistent results, then drop down to 1/80th etc...
I usually pan at around 1/40th-1/60th depending on if i'm getting paid or not lol.
Hey Fellas, had a good play with the camera last night. Some serious effort and some just goofing around.
Hey Matt, Kory & Nick these are taken at the netball courts just behind my house. It backs onto the bush which makes it a great locale for the dark bush sihouettes. We should set up a meet there and see what you fellas think of the location.
(I call that second to last photo - "my rocket ship")
oh yeah, was going to add that I bought a ball cap from bunnings that has 3 l.e.d.'s in the brim. one directly straight ahead and two pointed down from the brim at about 30 degrees. It worked a treat for this kind of work. Was funny cause I kept feeling like the Blair Witch project with the light pointing any direction I looked.
Was well worth the $20. For you noctural photography buffs would highly recommend.
patience, my young padawan apprentice. In time the power of the dark side will reveal itself to you.
Location looks quite good. worth a future investigation. Good to see you're out there playing around :)
here's a couple from twilight on friday night.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
