  • Replies 46
not on friday, but there were coppers on sunday, and saturday, coz they were waiting for the excited young men who weren't entrants in the show) who needed to prove they were full sick to do stupid stuff after the show.
None of our cars got dicked. If the car was illegal to drive Jack drove em outside the city and dropped em off. Otherwise we waited an hour after the show finished (we had to pack n stuff anyways) and then left with no fuss.
for those guys who saw it at the dyno day and are attending the meeting tonight, decide if you want me to make a set or 2 of glass gtr coasters and make sure you tell me on wednesday via pm or something lol :P
Guest INASNT
God....It's come to quick. I'll need some help on Friday night to put on my Nismo Demo Car stripes like in the picture below. Who's good at this??
R-tune%20R34
I might have a decal going on my car to.
U need to apply soapy water to the sides of the car then place the sticker and line it up straight. Then get something to squeeze the water from behind the decal and it should dry and straight in about 5 minutes depending on the type of glue used.
Good question... Gareth (J-Spec) mentioned something about someone able to help with it.
Will ask him tomorrow.
I'm getting my front lip fixed now (Aero Image are heros) but the car needs a detail.
Might ask around - just not in the mood to pay big coin for it.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
