What model coil pack do I need for skyline RB 25 ER33?
My mechanic is trying to match the current ones but he isn't familiar with this car . The person who does know is away for the rest of the week!
Required for normal daily driving , engine is non turbo version.
Reliability is required .its just a family car - no racing .
Edited by samuri
you could either get yellow jackets or splitfires or genuine nissan ones. yellow jacket will be the cheapest, followed by splitfires, with the nissan ones being the most expensive from memory.
for the model number you need, a quick search on the site of an online seller will give you the part numbers you need.
im getting stockies for about 220? aftermarkets go for like 400 - 600?
What serial number or model type do I need.
ER 33 RB25 DE series 1 skyline
my year model is 1996(I thought} but can only find coils to suit up to 1995
SF DIS-0001 or something is the spitfire number I think. Go on the nengun site and have a look it will tell you which one you need.
Please note there is a difference between R33 Series 1, R33 series 2 and R34 RB25 coilpacks
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
