lol@steve. Hehehe, matey VL's dont have a BOV from factory so the sound ur probably talking about it compressor surge. If u got a stock BOV on ur R33 take the vacuum pipe off the top of it, block it off so the manifold is sucking in unmetereed atmosphere and bobs ur uncle u have a vl sound. But this means ur bov isnt working and compressor surge is occuring. Not recommended but hey if u want the noise go for it!!!1
https://www.sau.com.au/forums/topic/37046-cooler-doseing/#findComment-740925
yeah the sound is from the compressor surging as its gets spun back by reverse air pressure cos the stock bov is blocked. its just like putting your head behind a desk fan and talking behind it, your voice gets "chopped". this is what happens to your turbo with the bov blocked, air comes in the other way and gets chopped by the blades. its been known to damage the turbo and slow down spool up times. the vl does it as it wasn't released from the factory with a bov so the air just back spins the turbo charger every time u close the throttle
aka "its a bad noise"
it gets amplified with an intercooler as it echo's through the piping too
https://www.sau.com.au/forums/topic/37046-cooler-doseing/#findComment-742632
a lot of people dont recommend blocking the factory bov. its there for a reason. numerous people have damaged their turbo's from doing this (blocking the stock bov) cos they want the crappy "vl turbo" noise.
it sounds retarded, affects spool up times and shortens the life of your turbo
hope you have some money around to rebuild the turbo if you wanna keep your stock bov blocked and have the silly noise :)
https://www.sau.com.au/forums/topic/37046-cooler-doseing/#findComment-742638
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
