Hey guys,
I've had a couple of incidents with my car and I was just wondering if anyone on here would be able to help me out with touching up my car..
There are 3 bits that needs sanding and painting, and to be honest, I don't really wanna spend $600 on a respray for bonnet and bumper...
I just need someone to help me touch it up, I don't expect a touch-up job that would turn out to look like Daniel's R34 Nur, I mean... Anything would make it look better than what it is now... I hope..
I'm willing to pay for the paints and labour, so if anyone here has experience or is a spray painter and would wanna do a backyard cash job, please let me know.
And PLEASE DO NOT refer me to DT panels or Micolour lol, or tell me that touching up will look crap and colour won't match, I just want a cheap touch-up job that looks okay...
Cheers
https://www.sau.com.au/forums/topic/370486-backyard-touch-up-paint-job/
  • Replies 49
Hey Charles, dude honestly that front bar is pretty much gone but if you really are hell bent on doing a el cheap o job then my suggestion is to find someone with a decent air compressor and a air sanding and paint kit and try doing it yourself, I had a friend who didn't know jack about paint and after a few tries his paint job looks pretty decent for a home garage job.
Honestly, you're better off repainting the front bar.
I once quoted $200 to paint in Midnight Purple by DT panels - which is apparently bit difficult paint to match.
The thing is... I got quoted, $300 for front bar, $300 for bonnet, then I want to fit new sideskirts $300.
That's $900... Which is half way to a full respray... and I just can't justify spending so much money on my car lol, because I know with my luck, once I get it all fixed, someone will just back into me =.=
EDIT: Or should I just wait until someone runs into me? lol
hey charles i got a compressor and all mate, quite happy to have a crack at it or give you a hand if you want to try yourself..Send me PM if you like we can do it easy even if we just fill it and touch it up with an airbrush should come up good enough..
Much better than what it is now anyway :laugh:
Charles, carbon fibre wrap it?
Can't believe I've just thought of this.
That could actually work too, carbon wrap both bumperss and the skirts..Its a bold move though
thats the problem with 2pak paints they are a bitch and expensive to fix.they dont just scrub out like acrylics the chip and crack so you cant just rub back and patch a section you pretty much have to repaint the whole panel..
Not anymore mate. I've spent a bit at vu's and always gives good prices. Wanted $300 for a GTR front bar in QM1 white
vu does an ok job but with paint you get what you pay for literally
True. My paint is 2 years old and is still awesome. Painted by Vu. Only scratches on the sideskirt when you open the door because of the poor quality kit
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
