Doubt it'll make a difference mate as soon as you hit 4000 it'll just spin then as well.
Infact off the line it might even spin a bit anyway. Wheelspin is fine, you are on street tyres so you cannot expect it to launch perfectly.
Just try a bit more right foot/left foot control with throttle/clutch. Combine that with you 16s @ 20psi
I reckon you could improve. Practice makes perfect anyway. Don't expect to be running the best times until you've done a good 20 passes and really worked out the feel of the car. Manual racing is quite difficult too compared to Auto.
yeah very true, im just hoping to equal my previous atleast and maybe 13.5 with a decent take off, i dont think the tein coilovers are doing any favours , they are as stiff as anything and bouncy on the street, but will my best with practice and report back..
will have some fun anyway, thats what its about lol,... give them hell! or as close to it hey..
With 220rwkw and a 1400kg car (without me in it) this was the best i could achieve
ET: 12.9
MPH: 109
60ft: 1.9
This was using 225 street tyres, 16inch wheels and 20psi. I had a perfectly working LSD too, which is important.
I was also using rock hard coil overs.
Must have done at least 60 passes, could be 80 or more and had a lot of runs between 12.9 & 13.1 so it was consistent.
Without providing the following info we really cannot help you workout where you are missing.
MPH:
ET:
60ft:
Power:
Don't expect just to be able to put the foot to the floor as well. It's not a GTR :)
My passes required careful throttle control and use of clutch and not always 100% drop clutch and plant foot.
1st pass
MPH-94
ET14.721
60ft:2.383
Power: 214rwkw 1Bar
tyre pressure : 30psi
2nd pass
MPH: 99
ET: 14.773
60ft: 2.476
Power: same
tyre pressure 20psi
track temp 11degrees
humidity 44
for comparison, other guy (looked like a hilux ute with V8)
MPH:114
ET: 11.876
60ft: 1.684
Power: shit load lol
Do you think have a smallish turbo like mine, 2871r is the problem?? too much bottem end power instead of comming on late once the cars got moving??
Edited by SliverS2
Hey guys,
went to the drags last weekend and was quite dissappointed with my time, embarrassed actually, lol... after previously doing a 13.8 with 195kw and crap suspension and tyres, i couldnt seem to get any better than 14.5 and i think its due due to the wheels spin/take off...
the car has much more torque and pull than before so i was expecting a low 13 as others were doing with similar power, a few things which have changed are, 18inch rims instead of factory rims, pwr fc, more boost, tein coilovers instead of worn out soft ones, heavy duty clutch instead of dying old one.
any suggestions ?? even on 2500rpm i was spinning them when the 13.8time previously was hardly any spin and all acceleration..:(
i noticed a 450hp r33 gtst doing mid 12's with massive wheelspin ,
all you need to know really is for drag racing applications;
soft susspension front an rear for maximised weight distribution,
larger sidewalls over low profile, again for helping shift the weight and applying tourqe to the ground..
correct tyre pressure for the tyres being used (low tyre pressure not always best)
an if et is what your after an you are using street tryes, an most semi slicks NO or minimal burn out..
and although it may be rough on the clutch,
riding it out of the whole untill you feel the bite then stepping off it..
with every pass you do observe things like rpm at launch an what you are doing with your launch weather you are dumping or riding your clutch,
an only after a few runs will you find how to get the best launch out of your set up..
Your 60ft's the what is hurting you mate.
2.4 is really average at best. Are you just dropping the clutch? Or feeding it in?
Get the 60ft down to 2.0 and you'd be prety close to a 14 flat.
However in saying that, there is no way you have 215rwkw with only 100mph. Its more like 170rwkw as with 220rwkw i was running 109-111mph. 10mph more, with a weight that would be very close to that of a R33.
So definately you are down on a lot of power for such low MPH assuming you aren't backing off before the end etc.
well ive got a dyno sheet saying 214kw and an old one saying 195, i think its fairly accurate,
i was trying to feed the clutch but it kept gripping and spinning the wheels , ive changed the avcr setting to -50% duty and softened up the tyres and suspension and seems to be launching better now, so will attempt again in the next few weeks
Dyno sheets mean nothing, MPH is a very good indicator of how much power you have.
Fact is with 5rwkw more, I was running 10mph more than you... That is a massive discrepancy.
You are 100% down on power, or backing off before the end.
I bet your MPH hardly changes on your next outings. A 220rwkw GTS-t should be running 13.0 all day.
what mods were changed to get you the extra 20kw? was a dyno run done immediately before the mods to see what the real gain was, rather than comparing an old graph to a new graph?
and have you overlaid the 2 graphs to see if you are down on power through the mid range at all?
maybe put it on a dyno at a different workshop and see what power it makes there. may possibly show that your 215kw isn't quite accurate.
Have read a couple of other car forums about drag racing.
The majority say that proper take-off on drags involve a lot of riding the clutch.
To control wheel spin you ride the clutch, not back off the accelerator. Get used to the smell of clutch if you want a great take-off :P
when i got the 195kw it was a stock computer without any tuning, the 215kw was with adding a pwr fc and tuning on 1.25bar but it was dropping off to 1bar by redline and also with splitfire coilpacks and walbro pump added
i will try again cause i feel like it has the power to do alot better, the launches were all spinning in first gear, even second and chirping third, so its all to do with the take offs, power is there to do alot better..
the 214kw graph is alot steeper and heaps more torque and earlier too, and on the road it pulls alot harder than before which was lacking, so i dont doubt the tuner or the graph...
Edited by SliverS2
ok. so it sounds like most of the issue is with the tyres. as people have said, get some stock rims (or 300zx rims as they are wider so you can fit wider tyres on them) and get some decent tyres for them. even have a look around for some used semi slicks.
by a decent tyre are we talking a soft jap tyre? what profile width do you reckon, as fat as possible???
I was doing 2.9 60fts with a 225/60/16
Just some shitty dunlop tyre, about $150 worth. So dropping back to 16s will help, but you clearly are lacking in practice at then moment as there is no way just going back to 16" rims/tyres is going to get you 0.5 of a sec
You need more practice, and whether you accept it or not - i tell you 100% right now you are down on power.
ok well ill see if i can track some of those tyres down, will just have to see about the power side of it, though you may well be right, could do with a check on the dyno to see if the boost controller is getting the most out of the setup..
just dont wanna pay for a full tune again
Ive been trying to figure out what is the best way to set up the boost delivery on my AVCR
eg, should i set it to 1BAR accross all the revs or stage it like 7psi upto 4000rpm then 1bar to 7000rpm,
a small exhaust housing might get choked up fast with 1bar straight away or would it be the same?
should just keep focused on one part of the track ie first half where the race is won an lost..
if your down on power you wont know untill your getting your first half of the track rite coz if your getting wheel spin in all of first, bit of second an chirping third
that will have an effect on your top end mph anyway..
once you master that part you will soon know if the car has power issues byy how the car is behaving at the top end..
first half of the track is all in your hands, where as the second half of the track 90% is down to the cars power..
couple of posts up someone commented on the smell of burning clutch..
perfect comment..
unless you have semi slicks an soft suspension, the launch is 80% in the left foot, clutch will start to smell but you have plenty of time between rounds
to let her cool ;)
perfect comment..
to let her cool ;)
:cheers:
  • 1 month later...
Solid diff mounts and rear subframe bushings helped me alot to transfer the torque better.At least a engine torque damper which helps shifting.Diff gears is also a good thing to do.Some how higher gears are pref over lower gears.
My set up was MAZWORX cross member,Solid rear bushing on both subframe and diff,HKS Hype D rear coil overs,2 way lsd can't remeber my diff gears but sure it was higher then 411s,17 x 9.5 wraped in yokohama advans which I still use or nitto 100 threadware tires pressure set at 28 left and 25 at right.Depends on which way the car tends to jump at launch.No front sway bar and oem rear sway bar.But this is when you know about suspension travel.
I have never drag race a awd.I only do rwd.Not sure if deleting the front antiroll bar will help awd aplications....Never been a fan of drag racing.We go there to goof around.I just love to use the launch controller on my hks.lol.So much fun.
I had it set at 5k rpm.But this depends on how fast your turbo spools which has nothing to do with your thread..Ebake tech helps as well.
  • 2 months later...
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
