Allmost all of the rubber in my car need replacing. Im after some advice on what I need to replace the rear cradle bushes.
Its a street driven vehicle but occasionally it gets used for drift and I'd like to hear from people with real experience on which option is best (or combination of) for the rear cradle.
Whats the go with all this crap advertised: Nolothoane kit, Alloy collars, Solid alloy bushes?, Pinaple rings etc.
What do i need to get the rear "tight"
I dont care about road noise or vibration.
https://www.sau.com.au/forums/topic/370862-rear-cradle-options/
no offence but those dont do shit all to fix worn cradle bushes. such a bandaid solution.
if your going thro the hassle of replacing cradle bushes.. you need to take the cradle out to do it. why not take the time and put an S14 cradle in it. they have better geometry's on the LCA for anti squat and will give you more traction. I have a machinist who does the solid cradle bushes offsetted to suit the s14 into a 32.
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
