Yeah, but as I've told you before, they don't have these tables in Nissan ECUs. Only the RB26 even has an inlet air temp sensor. The whole point of my post was that you have to work with what you've got. In the case of Nistune, it means that the knock maps are not always reliable, so you have to decide if you're going to try to live with random changes of map (when it shouldn't), or it never changing because it never detects knock even when it happens (which also occurs, and is of course worse) or whether you're going to disable it and tune sensibly to avoid the problem altogether. It is possible to tune so that you might miss out on some winter performance, but you won't ping it to death in summer.
Burnouts are dumb at the best of times. So I say that motors that cook as a result are not a problem, just an education.
nistune has coolant temp trim tables.
but yeah do what you said re just tuning for summer and itll be fine all year
Random changes....sounds a bit disconcerting for a daily driven car.
If I do go for a nistune/PFC the closest tuner will be nearly 2 hours away, which makes me think any drama's will be a big hassle for me.
There's no reason to be stressed about it. Once tuned, a nistuned ECU should be able to be left alone until you change something on the engine. Mine hasn't been hooked back up to the laptop since it was tuned years ago (apart from just to have a look at something.)
ok, cool. Well I am pretty much sold on the nistune, seems to be the best bang for buck option. And it seems they don't make PowerFC's anymore (not that it really matters).
What is the going rate for a nistune....tune?
guess i'll have to trawl through the QLD site to find some reputable tuners who are nistune friendly. Do I NEED a z32 or is just optional/better than the stock AFM?
And final question (I hope) - I have come across a 2nd hand ecu with nistune already installed, if I were to buy this would it be a simple plug and play and then getting it tuned to my mods?
Thanks again, you guys have been very helpful :cheers:
It has a resolution suited to higher airflow, so if you max out the stock one (~240kw ish) then you need a Z32 or it makes tuning very difficult.
Re the ECU no it isn't that simple, you cant just plug an R32 ECU into an R33, you need to wire it in.
Edited by Rolls
So my stock AFM should be fine for the ~200 mark? The ecu/nistune i'm looking at is out of an R34....
EFI do Nistune in QLD and the tuner sean is great, I had my R32 Nistuned by them it never missed a beat as long as I owned it.
I went a Power FC in my R34 GT-T and it's working great, I have had it installed since the car had it's first mods fitted, No issues with the unit what so ever.
Edited by RandomHero83
Rolls , what makes u think u have to wire in an r32 ecu to a 33?
Rolls only the VTC needs to be wired in on gtst's. But if u buy a programmed r32 ecu that has rb20 image u will have to either change the tps to a rb20 tps or send the board to NIStune to get a rb25 base image programmed.
On GTR as EAT ME posted, change a few settings in NIStune
That is right, I had to use a S1 rb25det TPS as the S2 one didn't work with the R32 ecu.
So yeah you have to "wire in" a few things, not very difficult though, but if you aren't electrically useful then you would need to pay someone to do it.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
