Reverted back to 2 piece driveshaft today, and noticed the yoke doesn't go all the way into the gearbox.
The 1 piece would go all the way in, now I know there is meant to be slack but I can't remember how much.
Can somebody take a pic of theirs with that circular cover off, show me roughly how much of the yoke is meant to be exposed with the centre bearing and diff ends of the tailshaft mounted ?
I've got like ...1in.++.
A31 rear tailshaft.
R32 front half inc centre bearing)
Edited by Nic_A31
https://www.sau.com.au/forums/topic/371502-rb20det-gearbox-yoke/
yea there is a lil bit of slack on my r32 front/auto ceffy rear tail shaft, works fine.
also mine drops some oil on the right angle when shaft is removed so seems to be normal, then again i have put more then 2l of in the box.
Oil meant to leak when the yoke isn't in the box :P
One of those things I actually didn't know first time I took tailshaft out - had a spaz thinking I had a f**ked box or something
2L is about right isn't it. I thought it was roughly 2.2 but never measure it, just fill it up to the plug.
Had a better look last night, it's more like 20mm of the yoke exposed, but that might decrease again when I actually mount the tailshaft to the diff.
Cheers fella's.
i made my own driveshaft, after i measured it wrong i realized the yoke shaft isn't in the gearbox like it should...>_<
the yoke is just half in the gearbox, when i did the auto to manual i was to lazy to customize it again and just tried,...never had a problem lol :worship:
surprisingly it works fine, drifted around a half year and still good:D
only problem is when i drive for example 80 km/h and clutch in to let the car roll the driveshaft vibrates like hell and shakes the car, on acceleration and deceleration normal^^
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
