I've noticed that to fit my QLD personalised front plate that you have to bend the plate and make it look all crappy.
I was thinking about trying to find some rubber spacers to sit behind the bolts and hold the numberplate off the bar so it can sit straight again, but the recess is pretty deep so it'd look pretty weird like that too. I've been looking for other 33's to go up and have a look, but haven't seen too many since I noticed this... :rolleyes:
What does everyone else (with a s2 r33) do with their front number plate?
Edited by tuna_144
https://www.sau.com.au/forums/topic/371572-r33-s2-number-plate-position/
you should be able to pick up a multi-size pack from any hardware shop, mitre 10, bunnings etc. just ask for metal or tube spacers, if you can find rubber ones there I'd get those & cut them to size until you find a fitting you're happy with
take your plate screw with you to find the right size so they don't stick out too much, you won't notice the gap after awhile anyway
no way my rear plates would fit without them :thumbsup:
+1
I have the metal spacers - 2x for each screw from Bunnings & got longer screws whilst I was at it > Perfect!
I was thinking metal spacers but I thought they might vibrate or rattle - a pet hate of mine. For those with the metal ones, do they make noise at all?
I went into bunnings and asked for spacers and got the :blink: look, so I may have to try a different bunnings.
I notice now that my friend has bought a GT-T that the GTS-t's number plate recess is like 2-3 times as deep, so he only needs tiny little rubbers to make the plate fit flush.
I've also found this driver side mounting bracket on one front bar in my searching:
What's the legality of mounting a number plate there in QLD?
Thanks for all the responses btw.
Edited by tuna_144
It can be side mounted as long as it is visible from 45 degrees and 3m away from the car at each side or something like that. Might be online somewhere?
I have metal spacers and they don't make any noise. They mount to the bumper by those speed nuts or whatever they are called. But they are rubber or plastic so don't vibrate.
Ive mounted mine in drivers side of the spoiler, along the lower lip , i cut down the standard plate to a personal plate size and just drilled some self tapping screw along the bottem to hold it,
I didnt want it mounted on the front cause it looked like it was blocking the intercooler a bit, i see that bumper has the number plate part cut out to make the mouth of the spoiler bigger, ive dont that too
Edited by SliverS2
I went through my shed, found some old fuel hoses and cut them 2 size and used them as spacers with longer screws, been on car for about 2yrs now and never fell off LOL WIN
Nice ride you got there, black is by far the best colour for a skyline i reckon
Why not just drill it into the bumper? Mine looks fine. Also makes the intercooler look more visible by having the plate higher.
Do you have any pictures to show what you mean? I'm guessing you mean like what 89CAL was referring to earlier, drill holes at the bottom of the plate and lift it?
That wouldn't change the recess issue (the gap behind the plate) would it?
Mine still uses the standard number plate mounts. Phils is done with self taping screws (?) through the bumper and into the reo
Nah just into the bumper plastic, normal allen key bolts. Holds fine. One side after 5 years is getting a little bit loose so next time I have the bumper off i'll put nuts on the back of them. Will also prevent them from getting stolen.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
