  • Replies 244
Posted Images
hey
Just emailed in my entry form and disclaimer form
paid by direct deposit - left a note in the email as bank didnt let me have reference in format requested but its all good n sorted moneys in the account requested.
cant wait, this will be my first DECA :D
PS where did everyone get there fire extinguisher's from?
Aasa can be done on the day. Make sure you being $50 cash. As soon as I'm near a computer later this mpening I will put the link here - you will need to fill it out and bring it with you.
On your entry form just put TBA or AASA on day
EDIT - go to this page and download the Club Racing License
http://australianaut...id=29&Itemid=45
thanks, will fill out the form to be ready for the day.
Autobarn and Super Cheap have them... :google:
Just make sure they have the metal cradle.
cheers...any idea on price for one of them?
$20 and make sure you bolt it to the car somehow, no screws, cable ties or gaff tape.
make a bracket that mounts onto the front pass seat bolts.
no bolts no pass :thumbsup:
really? i've had my extinguisher bracket secured to the side of my trans tunnel with self drilling screws for 4 years now. Never had a drama at any CAMS event, including sprints, hillclimbs etc. Its very secure, what is the issue?
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
