Al's Race Glides Just finished my gearbox off for my gtr which will be hitting the strip in the next few weeks. Car has made over 1000rwhp on a run in tune up and is now equipt with a 4WD T400 that has run 6.8 at 207mph in a rwd chassis car.
These boxes will be available to the public in the next few weeks. Gearbox packages will range from 800hp up to the 2000+HP application.
These are streetable gearboxes as i wish to have mine making around the 1300awhp all day every day on E85. Drive to the track and drive home.
PM me if you're keen
Was a shit fight to get an auto to hold power but looks like it has finally been done.
http://www.calaisturbo.com.au/showthread.php?p=2795161#post2795161
Julian
Edited by kil-351
car was tuned with the manual box in it as the auto wasnt ready, hence the dyno graph.. was on f**k all boost but at auto salon this year we will be chasing whatever the turbo will turn to plus a healthy shot of gas. Try and get 60+ pounds out of it before we get serious at the drag strip.
Thats awesome, sounds promising - when are you going for a full power tune? Will be interesting to hear how the block holds that.
Im going to put the auto box in it asap then drive it on the street the way it is for a few weeks before i turn it up. The block may be an issue as im still running water but i didnt break my single camer on 52 pounds so i think with maatouks tune up it should hold over 50 pounds before i spray it. Race it for a bit then try and feed the next 10 - 15psi
Is that a modified stock inlet I see, Julian? ;)
What is the price range for an Al's T400 GTR box?
yea stock inlet for now.. not having any problems with it. the box complete bolted in with neal chance converter, tranny cooler, shifter, tail shaft, all adaptors, output shaft etc etc is around 20k. Maybe a bit under
  • 3 weeks later...
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
